Results 1 to 6 of 6
Thread: Materials on hand
16th Aug 2020, 01:35 PM #1Member
- Mar 2012
- adelaide
- 91
Materials on hand
This may be an odd post but what materials to people keep on hand, this just for machining i have some sheet material but that's not what this is about, most of the things i get up to are on weekends and at night so its nice just to grab some thing from the rack and get into it, also with suppliers having minimum orders ,if i need some thing specific i have to bulk up the order to get to the minimum
so here is a rough list of what i have lengths are from 1.5 meters to about 100mm any smaller is just in the odds and ends box , there is no scrap/junk as my old boss used to say its just that some bits are a bit smaller than others
aluminium round may be 2011 and / or 6061 i mark the ends of the bars
100mm
50mm
40mm
25mm
12mm
10mm
an assortment of plate, flat and angle sections
Brass
32mm
19mm
an assortment of flat section
steel round
50mm EN36B
50mm castiron
32mm 12L14
1 1/4 12L14
25mm 1020 and 4140
24mm 1020
7/8 1020
19mm 1020
11/16 1045
16mm 1020
9/16 1020
13mm 1020
12mm silver steel
11mm 1020
10mm 1020
3/8 1020
8mm 1020
6.5mm 1020
and some assorted bits of flat BMS and some boiler plate that i slice bits off as i need
Aceteal rounds
32mm
25mm
20mm
i know the has been a bit long winded, this all stored on a single 1200 X 400 shelf and the longer bits standing up in 300 x 300 box
so its not a huge area, some times specific jobs i will order material in for as needed and some of this is leftover from jobs
how do others do it ? any other thoughts on grades to keep
what do i do, mess around with old cars and motorbikes and making bits to maintain the works shop, so not really making model engines or clocks or things like that
16th Aug 2020, 05:19 PM #2Member: Blue and white apron brigade
I'm nowhere near that organised.
Most of my stash is stuff scavenged from the Mens shed rubbish pile, metal merchant scrap bin off cuts, deceased estates, sides of the road etc, so I don't really know what specific alloy it is.
That's probably because most of what I make it doesn't really matter.
I tend to make do with what I have laying around and might buy something specific for 10% of projects.
16th Aug 2020, 05:34 PM #3Most Valued Member
I'm with Bob. No way do I keep a large inventory of lots of stock.
Most of my stuff is either scrap I have accumulated or, if I buy for a project, I try to buy offcuts at local steel place at a discount and always try to buy more than i need so I have extras.
If i go hunting for stuff at scrap metal, I'll often buy stuff if its a nice piece because at scrap metal prices, steel is a bargain!
16th Aug 2020, 07:48 PM #4Philomath in training
Not sure I'm much better. I have bits of brass up to say 3/4", lumps of steel (alloy and MS) and cast iron up to around 120 or so diameter, bits of plastic of various sizes, Al in reasonable lengths up to 50mm as well as a few chunks up to around 130mm. There is also some thickish steel flat (say 20 or 25mm) that used to belong to injection moulding dies. I just try to use it up. If I need something I generally just fossick around. There is usually something that will do.
17th Aug 2020, 10:27 PM #5
I'm similar to other guys, fair bit of steel, sheet steel, aluminum, brass, delrin etc.
It would take to long to catagorise it all, and it's all over the place.
Your organized, lolUsing Tapatalk
18th Aug 2020, 09:13 AM #6Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
we have about 10t+ of various material in stock at work, and about 50% of the time we don't have the right bit for the job at hand.
Hand Scraping a Hand Plane to .0001" Accuracy
By Ulma Doctor in forum METALWORK GENERALReplies: 4Last Post: 28th Feb 2015, 06:38 PM -
Raw Materials
By bigphill in forum METALWORK GENERALReplies: 1Last Post: 1st Apr 2013, 08:35 PM -
Materials used on Threaded lathe spindles.
By pipeclay in forum METALWORK GENERALReplies: 7Last Post: 4th Jul 2011, 07:51 PM -
Boring bar Materials
By Grahame Collins in forum METALWORK GENERALReplies: 14Last Post: 7th Jun 2011, 04:52 PM -
materials Mass Data
By Dusty Wheels in forum METALWORK GENERALReplies: 4Last Post: 31st May 2007, 12:28 AM
