Results 1 to 1 of 1
Thread: Soft Jaws !
    6,480
    Thumbs up Soft Jaws !
    I needed to make some more soft jaws for the lathe chuck. So yesterday I cut a chunk of 1/2" thick aluminium plate 50 mm wide by 5" long, to make some fingers that I could fasten to my existing soft jaws with the M6 countersunk screws into the existing threaded holes. I cut all the pieces on the bandsaw. I wish that I had bought one of these years ago, particularly when I think of all the times that I got back ache from hacksawing stuff.
    These pictures show the bandsaw setup for cutting the 50 mm by 125 mm piece of aluminium plate into 1/2" thick fingers.
    Here are three pictures of the aluminium fingers, drilled, countersunk and screwed to the ECJ soft jaws. I machined the tapers on the ends and fitted them to the jaws and bored a centre. I stamped them with the position in the chuck numbers, so that I will know which finger attaches to which jaw.
    This how they look on the chuck.
    Now to get on with machining my grinding spindle shaft !
  1. Soft Jaws.
    By BaronJ in forum METALWORK GENERAL
    Last Post: 19th Feb 2020, 04:51 AM
  2. Soft Jaws.
    Last Post: 14th Jan 2020, 08:13 PM
  3. Soft ride trailer
    By DaveTTC01 in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 29th Nov 2015, 04:39 PM
  4. soft soldering
    Last Post: 22nd Nov 2013, 10:19 AM
  5. soft jaws
    By azzrock in forum METALWORK GENERAL
    Last Post: 15th Sep 2011, 11:40 PM
