Results 1 to 13 of 13
Thread: Hammering HSS steel.
26th Jul 2020, 06:59 PM #1
Can HSS steel in its soft state
Be penned ie
What’s it deformation characteristics like.?
Will it yield like mild steel,? or is more prone to flaking an splitting.?
I would like to use some for a base of a hand plane,with the sides dovetail into the steel.
Using a double dovetail.
Like so.
I’ve started my first hand plane making project, an am already over using scrap mild steel with all its pits an defects.
Knowing that I will have too hand grind(lap them out)
An would like to use some precision ground steel for the base.
Saving a Ton of work, I already have my badge of honour for hand lapping old planes flat.
I have no need,or desire to repeat that unnecessarily.
In the sizes I want an considering I’m not wanting to go out shopping much these days plus I’m in no great hurry,
I Can have something like this delivered!!.
Cheers Matt
26th Jul 2020, 08:09 PM #2Member: Blue and white apron brigade
Sorry nothing like mild steel.
Most HSS comes in a prehardened state (if you belt it may shatter) and heat treating HSS is a PITA and requires a well regulated temperature controlled furnace.
Annealing: Heat to 1600°-1650° F, then cool in a furnace at 30°-40° F per hour to 900° F. Air cool. Hardness will be 241 Brinell maximum.
(1650-900)/35 = 30 hours!!!
The you have to reharden the stuff! once again a well regulated temperature controlled furnace.
Hardening: Preheat slowly to 1350°-1550° F and hold until thoroughly heated. Next, heat rapidly to 2150°-2275° F. Total heating time varies from a few minutes to a maximum of 15 minutes depending on the size of the piece. Oil quenching is recommended for developing full hardness, although air quenching and quenching in hot salt can also be done. When the material has reached a temperature of 150° to 200° F in the quench, temper immediately. The best tempering range is 1000°- 1100° F. Double tempering is recommended.
HSS is fine to make basic WW tools as is, cut/shape using abrasive disc and grinder. Its pretty hard too over cook it.
The rough looking chisel second from the left is a HSS blade.
Teh other two blADED TOOLS ARE Made from detempered old files.
26th Jul 2020, 09:22 PM #3
26th Jul 2020, 09:29 PM #4Gear expert in training
- 34
- 1,079
Finding it isn't hard, just do a google for "ground flat bar"
First result: https://www.edconsteel.com.au/store/...round/flat-bar
You gotta buy a 500mm length though
26th Jul 2020, 09:37 PM #5
26th Jul 2020, 09:39 PM #6Gear expert in training
- 34
- 1,079
Only way to find out
26th Jul 2020, 10:20 PM #7Member: Blue and white apron brigade
26th Jul 2020, 10:23 PM #8Gear expert in training
- 34
- 1,079
26th Jul 2020, 11:58 PM #9Best Regards:
27th Jul 2020, 12:03 AM #10
27th Jul 2020, 09:57 AM #11Member: Blue and white apron brigade
27th Jul 2020, 11:03 AM #12
Hi Simplicity
Welcome to the MetalWork forums
HSS is used for plane blades. HSS is not a good use for a Plane sole.
There was a bloke, a Derek Cohen from Perth who was on the Woodwork Forums all the time who makes his own planes -among other WW tools.
Derek has his on site about making woodworkers tools. He has an email contact on that site.
https://www.inthewoodshop.com/index.html
An email to him may likely yield some better information.
27th Jul 2020, 02:39 PM #13Golden Member
- Mar 2009
- 54
- 825
G'day Matt,
First let me make clear that I'm no wood worker and am more than happy with my old Stanley plane so please factor that in before considering my response.
I may be missing something but I reckon starting with a block of quality cast iron and machining away anything that's not a plane body would be a better approach.
Every plane I've ever seen either had a wood or cast iron body, I'm pretty sure HSS would be overkill.
I don't think a plane sole needs to be particularly hard just flat and CI is ideally suited to being made flat with simple tools right out of the box.
As much as I like the idea of dovetailing HSS I'm pretty sure any flatness present in the original stock would be absent by the time everything was assembled and you're back to lapping or surface grinding.
If having a brass body is your preference then you could still go with dovetailing on a CI sole then simply scrape it flat, much easier than using HSS.
A few members on here past and present have made planes from CI so hopefully they will add more wisdom but these are my uneducated thoughts.
Greg.
Looking for a steel rod
By juaniv37 in forum METALWORK GENERALReplies: 3Last Post: 22nd Jul 2019, 06:42 PM -
Loan of a Steel hoop or piece of steel with a hole about 350 mm in diameter
By BobL in forum METALWORK GENERALReplies: 13Last Post: 17th May 2018, 08:04 PM -
mild steel to stainless steel
By cava in forum WELDINGReplies: 8Last Post: 27th Nov 2014, 06:48 AM -
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
By fudo133 in forum METALWORK GENERALReplies: 3Last Post: 25th Jun 2014, 12:44 PM -
what steel
By eskimo in forum METALWORK GENERALReplies: 9Last Post: 16th May 2014, 09:24 AM
