Results 1 to 7 of 7
Thread: Lathe tool video
23rd Jul 2020, 11:50 PM #1
Lathe tool video
This video is somewhat long winded but is interesting. The grinding wheel he is using is a rough looking grey wheel !
https://www.youtube.com/watch?v=2R0l6I1yrrk
25th Jul 2020, 02:43 PM #2
results
One observation Ive made with grinding/sharpening HSS blanks or touching up old tools is: the metallurgy in the tools varies , they are not all the same. Seems that different brands have different elements .. cobalt or tungsten or whatever. Can be frustrating because you use a method with good results , try another piece of HSS with the same method and get a crap result
25th Jul 2020, 03:23 PM #3
I watched this video last night. Interesting. Couple of things that he did not address were re-sharpening and using the tool on steel. (Remarks in the comments suggest that it is used for machining steel). I guess that an angled holder could be used to give top rake for steel. No chip breaker with a longish cut at 0.5mm doc could produce an unruly steel thread.
If I understand the geometry correctly, this is very similar to a tangential tool.
Thanks for posting the link,
Findlay.
25th Jul 2020, 04:32 PM #4
radius
Noticed he doesn't grind a radius on the tool nose which just about everybody in the lathe world recommends for a decent finish .
26th Jul 2020, 01:00 PM #5
Tool Angle
Because the tool is presented to the work at an angle, the cutting is being done along the flank of the tool. The only time that the point is cutting is in the root of a shoulder.
Findlay.
27th Jul 2020, 12:35 AM #6
video
In many of the utube instructional lathe videos the instructor uses either free machining brass or aluminium as the example job, it all looks very easy it would be closer to the real world if they used black steel or something more challenging as the job piece
27th Jul 2020, 02:40 AM #7Senior Member
- Aug 2007
- 292
I only scanned the video to see the wheel. Industrial aluminium oxide wheels usually come in grey. The important component is the grit and bond the wheel has. If we were to take the wheel off and look at the code you would likely find it is the right wheel for HSS even though it looks just like a junky wheel on a cheap grinder.
Pete
Tool and cutter video.
By steamloco1954 in forum METALWORK GENERALReplies: 0Last Post: 8th Apr 2020, 10:10 AM -
Tool and cutter grinder video. How to build a work head.
By steamloco1954 in forum METALWORK GENERALReplies: 3Last Post: 29th Mar 2020, 12:06 PM -
form tool - interesting video
By steamingbill in forum METALWORK GENERALReplies: 6Last Post: 27th Oct 2014, 09:43 PM -
Harrison lathe video
By morrisman in forum METALWORK GENERALReplies: 3Last Post: 28th May 2014, 11:03 PM -
Tool & Cutter grinder video
By morrisman in forum METALWORK GENERALReplies: 1Last Post: 8th Mar 2013, 06:13 PM
