Results 16 to 18 of 18
Thread: Need setup for tailstock issue
23rd Jul 2020, 08:39 PM #16
Hi Phaser, Guys,
Good grief, how much are you using ! You only need a wipe down the tool or across the area where you are going to machine. I often just brush the cutter flutes, the heat causes it to migrate down into the cut. If you want cooling then flood and use a water based cutting oil, now that will get thrown about !Best Regards:
23rd Jul 2020, 09:43 PM #17Senior Member
- Nov 2012
- Mid North Coast NSW
- 423
Ha ha yeah but I was referring to soluble oil mix going everywhere.
With the Trefolex I just brush a little on, but the job, vise and parallels get pretty sticky, and so does the swarf which makes it hard to vac up later on.
By comparison, aluminium is a breeze cos the wd40 dries off and makes vaccing easy.
18th Jan 2021, 01:30 PM #18Senior Member
- Nov 2012
- 423
Finally got around to fixing the tailstock issue. (it does take me a while sometimes), (usually). lol
So, it didn't need machining at all. The crinkle paint is pretty tough and I thought it was paint over rough cast. Well, it is rough cast but not as rough as it first appears.
Anyways, I started scraping at it and found the crinkle would chip off with a little effort to reveal an already machined surface. Just had to use a file on one edge where they left a small burr and the blocks fitted straight in.
Well that saved some muckin' about with a fancy setup.
Electronics setup
By BobL in forum ELECTRICALSReplies: 0Last Post: 11th Jul 2017, 09:27 PM -
VFD Setup
By Auskart in forum METALWORK GENERALReplies: 6Last Post: 25th Sep 2016, 12:00 AM -
I have my MIG all setup, may just need a few pointers...
By mugget in forum WELDINGReplies: 25Last Post: 23rd Aug 2015, 09:38 AM -
Tig setup help asap!
By BLKWDW in forum WELDINGReplies: 7Last Post: 2nd Jan 2012, 07:38 AM -
3 Phase setup
By barkersegg in forum METALWORK GENERALReplies: 13Last Post: 8th Dec 2009, 12:17 PM
