Results 1 to 8 of 8
Thread: Denbigh Model "C"
12th Jul 2020, 01:32 PM #1
Denbigh Model "C"
A Denbigh Model "C" with a vertical head has become available for sale, albeit 200km away.
First thing i noticed in the photos was that it doesn't appear to have a quill.
Is that a limitation?
Any other info pros and cons appreciated.
12th Jul 2020, 01:43 PM #2Golden Member
- Jul 2011
- 837
12th Jul 2020, 01:52 PM #3
12th Jul 2020, 03:58 PM #4
Hi
I have a model C in rough condition, it came with a vertical head . I believe there are at least two types of vertical head . They are a 'no frills' machine but seem to be very solid in construction.
I spotted one of these mills in almost mint condition along with a Holbrook T15 lathe in similar condition on EBAY some years back, a deceased estate sale. I asked the seller for a Buy it Now price for the lathe had a look about an hour later and she had put on something like $500 , as you can imagine it was gone in two seconds flat .
12th Jul 2020, 04:40 PM #5Most Valued Member
- Healesville
- 2,129
I think i paid 300 for mine with a vertical head, the high speed head would be a plus as mine is pretty slow. It has been a handy machine for me but be aware that if you want to get anything close to accurate then you need to set up and use indicators, I don't think it would be worth fitting a dro to it but it would help.
My dividing head pretty much lives on this machine and I probably use it mostly for drilling things like bolt holes in flanges ect with the head turned so that it is parallel to the table.
These machines are handy but definitely not an all-rounder so for you it really depends on what you want/need, if its cheap then
it could be a good toy to do a few jobs for you.
12th Jul 2020, 05:05 PM #6
Thanks for that info. I am thinking that it probably isn't the one for me, as I want an "all-rounder", and it isn't cheap at $1500 plus logistics.
It is also 3ph which I don't have, so add a few hundred more for a suitable VFD and suitable 3ph motor to run off 240 volts.
Oh well, keep looking I guess.
13th Jul 2020, 07:56 PM #7Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
would defiantly pass on that mill, way too expensive. I own 2 and paid $900 for one 20 years ago and $120 for the other about 4 years ago. They are a ok mill if you just leave them setup for one job, but for that money you should be able to find something much better.
13th Jul 2020, 08:59 PM #8
Hercus model "O"
By Ulfr in forum THE HERCUS AREAReplies: 29Last Post: 23rd Oct 2020, 11:03 PM -
"Defiant" floor model no 80 Milling machine, Thomas herbert & Co, Sydney
By myworkshop97 in forum ANTIQUE AND VINTAGE MACHINERYReplies: 8Last Post: 6th Apr 2018, 08:33 PM -
anyone have old "Model Engineer" mags
By rfurzer in forum METALWORK GENERALReplies: 12Last Post: 15th Oct 2010, 10:11 PM -
Opposing toothed "Clutch-Plate" Nuts? (a bit like "Castle" Nuts...)
By Batpig in forum METALWORK GENERALReplies: 6Last Post: 5th May 2009, 08:18 PM -
Difference "Galvanised" and "Primed" Steel
By Fr_303 in forum METALWORK GENERALReplies: 4Last Post: 22nd Jan 2008, 05:59 PM
