Results 1 to 15 of 43
Thread: Hair Thin Cuts in a Metal Comb
12th Jul 2020, 12:58 PM #1Novice
- Jul 2020
- Brazil
- 16
Hello there!
I have a future project of making a music box!
Since it's not easy to buy a good metal comb, I want to make a metal comb of my own.
There is a picture of a really small comb used in a cheap music box mechanism from China.
The dimensions are: 24mm x 16mm x 1.5mm [0,94 x 0,62 x 0,05] inches(really small)
1) My question to you all is, how in the hell they made all those 17 hair thin cuts in that small plate metal??
2) Whats would it be a viable way to make a metal comb? Even if it was bigger than the one in the pic.
I tried to make a metal comb with corel then sending to a place that makes metal laser cuts, but it was not possible because it was so small that the fins was gonna melt(at least that they told me that)
Thank you very much!
12th Jul 2020, 01:10 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
The fins will not melt, they didn’t want the job. Most CNC cutting places are not interested in DIY projects as they aren’t economically viable.
You could cut the slots in that with a cutting disc in the end of a Dremel tool and a steady hand. If you don’t have a steady hand you could rig a guide fairly easily with a couple of pieces of timber.
12th Jul 2020, 01:52 PM #3Gear expert in training
- 34
- 1,080
12th Jul 2020, 01:56 PM #4Novice
- Jul 2020
- Brazil
- 16
Thank you for your answer!
Before sending the file, I already thoght of that problem and made a A4 size file full of combs to make more viable for them.
When they replied to me, they told me that "cutting in carbon steel [1020] 0.5mm thick has no way to do it because the laser will melt the fine parts of the comb, this type of cut we recommend making in stainless steel"
After that, I asked them to cut in a carbon steel with a 1.5mm thick and they told me that "the greater the thickness, the greater the distance that must have between the cut lines". After that, I replied again and got no answer anymore.
I wonder if I made a bigger size file like a A3 or A2 to make them more intersted or just search for another place( Although there are not many CNC cutting places in my town...)
I like the Dremel idea but I need precision. If you or anyone else could give me more ideas or ways of doing this kind of cut I would really appreciate it!
I found a video on youtube on how a music box is made, at 0:55 they briefly explain how the comb is made using a circular saw with some oil that appears to make perfect cuts in the plate.
https://www.youtube.com/watch?v=RXf924CGLbs
Thanks again!
12th Jul 2020, 02:04 PM #5Novice
- Jul 2020
- Brazil
- 16
Thanks again!
12th Jul 2020, 02:25 PM #6Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
17 cuts with 1mm thick cutting disc would leave nothing left, the part is only 16mm wide.
12th Jul 2020, 02:31 PM #7Novice
- Jul 2020
- Brazil
- 16
Thanks again!
12th Jul 2020, 03:45 PM #8
Jewellers coping saw blades can be had down to 0.2mm maybe finer.
Rig the material between two stiffening parts (wood, plastic, or similar) and get'er done.
12th Jul 2020, 05:08 PM #9Senior Member
- Oct 2015
- melbourne
- 473
I'm interested to, as I have an old music box I want to restore.
Given it seems so difficult, I wonder how the originals were made.
Looks like slitting saws are available at 0.2mm. I wonder if that would work.
12th Jul 2020, 05:47 PM #10
Hi Commander, Guys,
That is how the Swiss music box makers did it long before power tools. Scribe lines where you want the cuts and follow the lines. I actually have some jewellers saw blades that I bought a couple of years ago from a firm in Australia. I made a frame for them, actually very easy to use as long as you keep the blade taught and don't try to rush the cutting. They are very brittle and will break if you do.Best Regards:
12th Jul 2020, 06:57 PM #11Member: Blue and white apron brigade
Anyone for EDM
12th Jul 2020, 07:45 PM #12Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Water jet cutter.
12th Jul 2020, 07:49 PM #13Gear expert in training
- 34
- 1,080
Waterjet has about a 1mm wide cut, so no good there. EDM would be the go if you know someone who has one
12th Jul 2020, 11:34 PM #14Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
12th Jul 2020, 11:49 PM #15Novice
- Jul 2020
- Brazil
- 16
Thanks again!
Another project functional - the MacPhersons planer cuts metal
By PDW in forum METALWORK GENERALReplies: 25Last Post: 1st Nov 2015, 12:40 PM -
How do I make one of these (long thin metal thing)
By Arron in forum METALWORK GENERALReplies: 17Last Post: 7th Sep 2013, 04:31 PM -
Welding applications and thin metal
By Grahame Collins in forum WELDINGReplies: 21Last Post: 10th Nov 2007, 01:36 AM -
repairing thin metal
By JB in forum METALWORK GENERALReplies: 11Last Post: 15th May 2005, 10:25 PM
