Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
  1. #31
    34
    1,079
    Yep, down to 0.1mm
  2. #32
    7,188
    Quote Originally Posted by frnnd View Post
    Should be possible to do it with a plate of aluminum?
    I've seen some music box combs made out of Al.
    Here's a link showing various sizes of Jewellers saw blades down to 0.17mm
    https://www.cooksongold.com/blog/jew...-to-saw-blades
    There are small scroll saws available used by jewellers but not sure they would hold the smaller blades.
    I'd be trying youtube to see what they do with these saws.
    I've seen a jeweller manually cutting straight cuts about 15 mm long with a 0.2mm blade in a Jewellers saw in some <1 mm thick silver sheet and it looked like it took considerable skill just so's not to break the blade. I remember she said getting decent underside support reduced the likelihood of breaking blades. Again check out Youtube to see their setups.
  3. #33
    Jul 2020
    Brazil
    16
    Thank you all very much for your answer and ideas. I think I'm gonna try the slitting saw or the saw blade, which one is more precise and cheaper for that job.
    Still don't understant why a cnc laser cutter won't do it...
    Thanks again!
  4. #34
    Oct 2015
    melbourne
    473
    The slitting saw is a circular saw blade. It needs to be mounted to a holder and is used in either a milling machine or a lathe, with the work piece mounted on a moving table of some sort, so it can be 'pushed' into the blade, without twisting out of line.
    Coolant used to keep it...cool...or go slow.
    Maybe try a different laser cutter company.
    But be clear on what you want - material, thickness, quantity.
  5. #35
    Jul 2020
    Brazil
    16
    Quote Originally Posted by russ57 View Post
    Yes, I was talking about the Jewellers saw blades and the slitting saw.
    In your opinion, what would be best for this job?
    In any case, I would have to buy a milling machine, a mini lathe or a jigsaw table.
    I think the mini lathe or the milling machine would be best.
    The other side of the metal comb has this lower level that seems to be made with a milling machine.
    So if I buy a milling machine, it should be possible to do both the cuts and the thinning on the other side, right?
    Sorry for my wrong spelling.
  6. #36
    Nov 2018
    Tasmania
    97
    If you use a slitting saw I would make sure to have some sacrificial backing material behind the comb
    The metal is thin and the fingers long, so they will be prone to bending under the cutting forces
    So the backing piece will stiffen the job and prevent it moving
  7. #37
    Jul 2020
    Brazil
    16
    Quote Originally Posted by TommyGMachining View Post
    All of this is a lot of work to cost less than a dolar...
    I really want to know what those chineses do to make it so cheap.
  8. #38
    34
    1,079
    I know we keep saying this, but....CNC
    They will have machines set up with jigs dedicated to producing that one part all day, robotic loading and unloading
  9. #39
    Mar 2011
    Southern Flinders Ranges
    1,552
    Quote Originally Posted by elanjacobs View Post
    And any person within the manufacturing process or supply chain is likely subject to a myriad of human rights abuses. The race to the bottom doesn’t come without human cost associated. Pushing those out for $1 is at that price point.
  10. #40
    Dec 2005
    South Australia
    1,657
    "I really want to know what those chineses do to make it so cheap"
    As Elan said, also they work for practically nothing.
  11. #41
    Mar 2012
    adelaide
    91
    i don't thing they were made in a CNC , too slow ,i think they would be gang milled with the different dia, slitting saws in a stack, i don't understand your confusion as to the cost of this sort of thing from China, its a police state paying 3rd world wages and 3rd world working conditions for this type product, the products that have higher value, the workers get payed more and the working conditions are better
  12. #42
    34
    1,079
    Quote Originally Posted by twopintsplease View Post
    Now THERE'S a good idea, would never have even thought of that.
  13. #43
    Mar 2012
    adelaide
    91
    after reading my reply , i don't think i made it clear the parts (comb) been machined are stacked as well providing support for the thin individual parts, with ganged multi dia. slitting saws, hundreds of parts an hour from simple machines
  1. Replies: 25
    Last Post: 1st Nov 2015, 12:40 PM
  2. How do I make one of these (long thin metal thing)
    By Arron in forum METALWORK GENERAL
    Last Post: 7th Sep 2013, 04:31 PM
  3. Welding applications and thin metal
    Last Post: 10th Nov 2007, 01:36 AM
  4. repairing thin metal
    By JB in forum METALWORK GENERAL
    Last Post: 15th May 2005, 10:25 PM
