Results 16 to 30 of 43
Thread: Hair Thin Cuts in a Metal Comb
12th Jul 2020, 11:52 PM #16Novice
- Jul 2020
- Brazil
- 16
13th Jul 2020, 12:06 AM #17Gear expert in training
- 34
- 1,079
13th Jul 2020, 12:20 AM #18Novice
- Jul 2020
- Brazil
- 16
There is this video on youtube that explains briefly at 0:55
It shows a circular saw but with some kind of oil...
https://www.youtube.com/watch?v=RXf924CGLbs
The comb I want to make doesn't need to be as small as the on in the picture.
I need a comb that works and has a way of doing it, if possible.
13th Jul 2020, 01:01 AM #19
13th Jul 2020, 01:28 AM #20China
- Dec 2005
- South Australia
- 1,657
If you have a lathe or a mill you could use a slitting saw ,with appropriate custom fixture and coolant
13th Jul 2020, 02:02 AM #21Novice
- Jul 2020
- Brazil
- 16
1) The mechanism with the metal comb costs like 5 bucks, so I imagine that it's not a expensive or complex procedure to make all of those cuts.
Considering that, what could be the possible procedure used in making this small metal comb?
2) I don't need to make a really small comb like that, if the cuts needs to be wide, so be it. Whats procedure can I use considering that I need precision in those cuts?
In the video I mentioned before, they use some kind of circular saw with some oil to make the cut. Does anyone know that procudure and machine?
This is a pic of the video:
13th Jul 2020, 02:17 AM #22
Hi Frnnd, Guys,
That would be quite easy to do on the lathe, and you can get slitting saws of almost any thickness. I have some that are only 5 thou thick, but its very easy to strip the teeth off those or break them.
The slitting you have seen in that video is done under CNC control.Best Regards:
13th Jul 2020, 09:19 AM #23Most Valued Member
I don't think either of those metals are suitable for the comb. They are heat treated after cutting to give the ringing sound. Untreated steel would sound very dull.
This article talks about the combs being heated to 'glass hard' after cutting. I don't think you can achieve that with 1020.
https://www.thenakedwatchmaker.com/m...ened)%20twice.Chris
13th Jul 2020, 11:21 AM #24Gear expert in training
- 34
- 1,079
13th Jul 2020, 06:43 PM #25Senior Member
- Jun 2016
- 283
A stack of slitting saws of the required thickness, with spacers between them.
Low revs - you approximate the speed of a hacksaw blade. Low feed rate to match.
The oil is to wash the swarf away, which can be crucial. Nothing like a jam.
I have done similar with a manual mill, and with a CNC. I use HSS, but you can get carbide.
Roger
13th Jul 2020, 07:07 PM #26Gear expert in training
- 34
- 1,079
Not sure a stack would work with each slot being a different length...
13th Jul 2020, 07:25 PM #27Senior Member
- Jun 2016
- 283
Oops!
Oh well, CNC with a single slitting saw, multiple cuts. It's just g-code ...
Roger
14th Jul 2020, 09:52 AM #28Novice
- Jul 2020
- Brazil
- 16
Considering the comb in the picture is from a really cheap mechanism from China, there has to be a inexpensive way to do it.
I costs less than a dollar for just one entire mechanism.
https://www.aliexpress.com/item/10000133302865.htm
How can they make it so cheap considering that the comb is something more complex than the other parts?
Should be possible to do it with a plate of aluminum?
Thank you all for your answers!
14th Jul 2020, 09:54 AM #29Gear expert in training
- 34
- 1,079
14th Jul 2020, 10:26 AM #30Novice
- Jul 2020
- Brazil
- 16
Another project functional - the MacPhersons planer cuts metal
By PDW in forum METALWORK GENERALReplies: 25Last Post: 1st Nov 2015, 12:40 PM -
How do I make one of these (long thin metal thing)
By Arron in forum METALWORK GENERALReplies: 17Last Post: 7th Sep 2013, 04:31 PM -
Welding applications and thin metal
By Grahame Collins in forum WELDINGReplies: 21Last Post: 10th Nov 2007, 01:36 AM -
repairing thin metal
By JB in forum METALWORK GENERALReplies: 11Last Post: 15th May 2005, 10:25 PM
