Results 16 to 19 of 19
13th Jul 2020, 09:59 PM #16New Member
- Jul 2020
- UK
- 61
- 8
I've solved it! There were some very tiny nuts already on there that can be taken off, and then I get the depth that I need! Silly me!
14th Jul 2020, 12:07 AM #17
Pincho your mailbox is full, you need to delete some mail !
14th Jul 2020, 12:02 PM #18Golden Member
- Dec 2007
- 574
Don't know if you have already done the job but if I was doing this I would find a piece of metal (steel) and screw it to a block of wood as in the sketch, hold the wood block in a vice or clamp it to the benchtop - drop the nuts one at a time into the hole - run a file over the nut until you hit the steel plate, rinse repeat until all nuts are done.
In scratch building a guitar amp a short while back part of the process was making the turret boards to hold the components - I ordered the wrong size turrets and needed to reduce the length by 1.5mm - I found an old bit of steel plate drilled a hole to take the turret and ran a file over each one until I hit the steel plate, approx 140 turrets, it was tedious and repetitive but I had it done in around 30mins.
22nd Jul 2020, 01:50 AM #19Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
Mitutoyo thickness guage
By robyn2839 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 13th Feb 2016, 02:52 PM -
Amps to metal thickness?
By Danger Mouse in forum WELDINGReplies: 10Last Post: 4th Apr 2012, 04:06 AM -
parrallel thickness
By welder in forum METALWORK GENERALReplies: 7Last Post: 7th Aug 2011, 07:18 PM -
Opposing toothed "Clutch-Plate" Nuts? (a bit like "Castle" Nuts...)
By Batpig in forum METALWORK GENERALReplies: 6Last Post: 5th May 2009, 08:18 PM
