Results 1 to 4 of 4
11th Jul 2020, 02:55 PM #1Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Shaper feed screw jamming ????? Help needed.
Hello to all.
Please combine your many years of experience and find me an answer.
Last weekend the shaper crossfeed screw became difficult to operate. I lubed it all, cleaned the screw and oiled it, backed off the gibbs, cleaned them and reinstalled. It got that hard to turn the hand wheel I decided to strip it down and remove the swarf that was obviously in the shaft nut. The hand wheel and ratchet gear are roll pinned to the shaft and the only endplay adjustment is the two nuts on the other end. I took the hand wheel off and the drive cover with the feed lever as well. To my surprise I could turn the shaft with the ratchet easily. It is now easy to thread thru the nut. I can't easily remove the screw as it is burred a bit where it has worked in the nut but it came out 250mm and was in fine condition. There is no galling or pick up in any part and it was all dripping in oil.
This all happened once before and the result was put it back together and it was perfect. Today will see it go back together after a good deburr but I'm scratching my head. How can it jam up and show no sign of distress. Even the part of the screw most used showed no signs of pick up or damage.
Your thoughts?
BC
11th Jul 2020, 03:34 PM #2Most Valued Member
- 2,671
The only things I can think of over the years that have behaved like that have had some sort of play in them and end up with something cocked/wedged.
Pulling them apart removes the jam, a bit of cleaning or lube stops it happening again for a while.
11th Jul 2020, 06:27 PM #3Best Regards:
12th Jul 2020, 03:54 PM #4Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Shaper trouble.
Hello again. I did a good inspection while I had the feed gear apart and the wear is minimal. Most parts still have machining marks. It is a low hours machine. Today I thought of the housing that goes from the ratchet to the feed adjustment drive gear. The whole lot can swivel to align and may be putting pressure on the casting. When I fired it up there was no oil pressure. I removed the action cover and found a congealed ball of oil around the pick up strainer. So, more pics next week.
At least today was model steam train club action.
BC
Feed Screw Wear
By Oldneweng in forum METALWORK GENERALReplies: 11Last Post: 12th May 2017, 04:52 PM -
Feed Screw mis aligned
By oohsam in forum METALWORK GENERALReplies: 12Last Post: 23rd Jun 2014, 07:25 PM -
Shaper table feed ratchet
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 7th Jun 2012, 02:27 AM -
Removing a Sheraton compound feed screw
By coffeefro in forum METALWORK GENERALReplies: 8Last Post: 3rd Oct 2011, 09:42 PM -
cross feed screw
By azzrock in forum THE HERCUS AREAReplies: 57Last Post: 6th Feb 2011, 05:41 PM
