Results 1 to 3 of 3
Thread: Cutting the Quick Way
9th Jul 2020, 11:25 PM #1Golden Member
- Jun 2005
- Helensburgh
- 618
Have a look at these Diablo blades escpecially the circular saw at normal speed. Ignore the presenter.
CHRIS
10th Jul 2020, 08:55 AM #2Member: Blue and white apron brigade
I have one of those Diablo reciprocating saw blades (and the same Makita reciprocating saw) and it is indeed a very useful blade. It cut the 12" hole though the mens shed wall (3 layers of Colorbond - like butter. Noisy but good. The reciprocating saw gets more use in the garden than the shed.
I also have an equivalent of the Diablo angle grinder blade (mine is a Lennox) and have used it in my metal cutting mini table saw in which I normally use the thinnest abrasive blades. It does make less dust and sparks but it has a slightly wider kerf than the abrasive blades. I did some COMPrative tests of this blade in 2017 see https://metalworkforums.com/f65/t201...ks#post1927317. The abrasive disc also leaves a cleaner cut.
For small pieces of stock I generally prefer fixing the blade in place and moving the stock using a mitre slide etc.
As for the circular - I d get one if I could get "teeth muffs"
10th Jul 2020, 06:51 PM #3
Hi Chris, Bob, Guys,
They look good, but as you said very noisy ! Good for site work though.Best Regards:
Plasma cutting capacity or waterjet cutting connections?
By jhovel in forum METALWORK GENERALReplies: 25Last Post: 4th Apr 2014, 11:06 AM -
quick Question
By leroy in forum METALWORK GENERALReplies: 6Last Post: 6th Sep 2012, 03:46 PM -
Quick Screw-Cutting Guide
By Article99 in forum METALWORK GENERALReplies: 12Last Post: 25th Jul 2007, 11:14 PM
