Results 1 to 11 of 11
Thread: Diamond cup wheel
5th Jul 2020, 09:50 PM #1Most Valued Member
- Healesville
- 2,129
Diamond cup wheel
Hi, I would like to make the shaft for this grinding wheel before it arrives, can anyone with experience with these please tell me the
diameter and length of the bore?
The description says 20mm for the dia but I would like to know what it accurately is.......
https://www.ebay.com.au/itm/Diamond-...72.m2749.l2649
thanks, shed
5th Jul 2020, 10:25 PM #2Most Valued Member
- 5,942
Sorry I can't help you as to the size, but will this be mounted permanently on a machine, or removed from time to time? Asking as normally they are mounted on a boss.
If it's going on a boss, the whole thing could be premade, and just the final trimming of the outer shaft skimmed to suit.
5th Jul 2020, 10:38 PM #3Member: Blue and white apron brigade
- 7,182
5th Jul 2020, 11:15 PM #4Most Valued Member
- Healesville
- 2,129
Thanks guys, understand that a measurement with ruler or vernier is not what I am after, but anyone that can take a measurement with an internal mic that has been zeroed with a standard should be close enough.
Bob, 120 grit
5th Jul 2020, 11:39 PM #5Golden Member
- Dec 2007
- 574
The one I ordered a while back it was in fact 20mm.
6th Jul 2020, 12:59 AM #6
All the ones that I've bought have been exactly 20 mm bore.
I've a piece of precision ground bar that is 20 mm diameter and its been a tight push fit in them all.Best Regards:
6th Jul 2020, 11:05 AM #7Member
- Apr 2015
- Tungkillo, South Australia
- 87
- 74
I have 3 for my D-Bit grinder and another one on its way from your ebay URL. Mine are slightly loose on a Stainless round bar that measures 20.00 mm.
Charles
6th Jul 2020, 01:00 PM #8Most Valued Member
- Healesville
- 2,129
Thanks fella's, that gives me enough info for the shaft dia..
What is the depth of the hole (the thickness of the flange)?
6th Jul 2020, 05:20 PM #9
22nd Jul 2020, 05:22 PM #10Member
- Apr 2015
- 87
- 74
I ordered one of the 80 grit wheels and it arrived in 10 days. The wheel looks quite impressive, I'm not sure what metal is used for the actual wheel but is gold colour plated and weighs .527Kg. The grit is plated directly to the metal at the rim. A Mitsubishi caliper measures the hole 20.00 mm, the thickness at the hole 12.5 mm and the OD 100.5 mm. HTH.
I won't be trying it for a while so I won't find if the plated 80 grit diamonds have a reasonable life. Cost was AU$29.89 with free postage. In my case, it is nicely (laser?) etched '80'.
Charles
26th Jul 2020, 12:08 PM #11Member
- Nov 2016
- Gulfview Heights, Adelaide
- 83
I was thinking about getting one of these diamond wheels to sharpen carbide router bits on my tool and cutter grinder.
What grit would be suitable for this?
Truing a diamond wheel - what to use ?
By johntopp in forum METALWORK GENERALReplies: 38Last Post: 28th Jul 2015, 09:02 PM -
Re-shaping a diamond wheel
By GSRocket in forum METALWORK GENERALReplies: 4Last Post: 6th Oct 2012, 09:41 PM -
Ebay Diamond wheel dressers
By argeng in forum METALWORK GENERALReplies: 6Last Post: 17th Aug 2012, 11:08 PM -
Diamond wheel defect - safe?
By Bryan in forum METALWORK GENERALReplies: 16Last Post: 25th Apr 2012, 05:04 PM
