Results 1 to 6 of 6
Thread: Slot Drill Size
2nd Jul 2020, 04:52 PM #1Golden Member
- Apr 2009
- Kingswood
- 930
Slot Drill Size
I just did a job using a new 2-flute solid carbide slot drill in 6061 aluminium on my CNC mill.
A quick check with a caliper said about 3.85 mm, so I "assumed" it would cut 4 mm.
Not so, it actually cut like a 3.85mm - duh !
So, measured carefully the flutes, also 3.85 mm.
5/32" is 3.97 mm, 9/64" is 3.57 mm, so it does not appear to be imperial.
Is it normal for cutters like this, probably purchased cheap somewhere, to be somewhat smaller than the expectation ?
I will start checking actual cutter dimensions for future jobs.
Keep well,
John
2nd Jul 2020, 06:00 PM #2Gear expert in training
- 34
- 1,079
Just had a look through the Guhring catalogues and their tolerance on flute diameter is generally h10 or e8, which would make a 4mm endmill 3.952 - 4.000mm or 3.962 - 3.980 respectively.
Some tolerance is to be expected, but 0.15 under is waaay not acceptable.
2nd Jul 2020, 07:14 PM #3Senior Member
- Sep 2009
- Newcastle
- 342
I've found cheap Chinese carbide is sometimes under size by a far amount. I assume they are starting with a nominal size blank and then grinding a bit off.
Not a big issue for me using CNC so long as I remember to check actual cutter size...
11th Jul 2020, 11:10 PM #4Senior Member
- Mar 2013
- Mt Pleasant SA
- 126
Back in the olden days HSS slot drills always had a (-) tolerance whereas endmills always had a (+) tolerance but agreed -0.15 on 4mm is a bit gross. Hardly the end of days tho'.
12th Jul 2020, 12:10 AM #5
I think I would prefer undersized slot drills to oversize ones, at least you can always take a finishing cut !Best Regards:
13th Jul 2020, 06:53 PM #6Senior Member
- Jun 2016
- 283
Dear me. Where did that come from???
But yes, if it is undersize you can handle that. In fact, I often prefer to do it that way, after micing the cutter carefully.
Roger
Tap Drill Size Calculator
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 21st Apr 2020, 10:33 PM -
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 1Last Post: 19th Jun 2019, 06:40 PM -
What size drill for a 5/16 reamer?
By ventureoverland in forum METALWORK GENERALReplies: 31Last Post: 8th Sep 2014, 10:12 PM -
Slot Drill Sharpening - A Case of Making Do ( or not really )
By Anorak Bob in forum METALWORK GENERALReplies: 12Last Post: 29th Oct 2013, 09:37 AM -
tee slot size
By welder in forum METALWORK GENERALReplies: 3Last Post: 25th May 2010, 05:38 PM
