Results 1 to 8 of 8
    Nov 2012
    Mid North Coast NSW
    423
    Default Triangles for machining
    Just finished making these for milling setups. 45deg and 60/30deg.
    I made them on the CNC from 1/4" perspex and they are both 100mm on the hypotenuse.
    There's no way for me to check them for accuracy but they should be aweful close since they are mathematically produced.
    If anyone is interested in having the G-code just let me know and I'll post it.
    Nov 2017
    Geelong, Australia
    57
    2,673
    Nice!
    A reasonable way to check them would be to cut another two of the 30/60 and then you could put 30+60 and check for square.
    Use the third one for 30 +30+30 to make sure you haven’t got 28 + 62 deg etc.
    The 45deg one you should be able to just check against a second one.
    Nov 2012
    Mid North Coast NSW
    423
    Nice!
    Yeah I knew that. I just didn't want to cut any more lol.
    They should be spot on though. They were designed in Autocad using exact angles, processed in Fusion360 for the tool path, then cut with CNC.
    6,480
    Hi Phaser, Guys,
    Making another one would be a test of how accurate your CNC is !
    Nov 2012
    Mid North Coast NSW
    423
    Hi Phaser, Guys,
    Ha ha no no you're not talking me into it
    Jul 2006
    Athelstone, SA 5076
    4,258
    Nice!
    failing that ...he could make some for us and we could check and advise him if they're any good
    Nov 2012
    Mid North Coast NSW
    423
    Making these triangles has made me realize something that could be significant to some people.
    If you have a lathe where the dials read direct, and you take a 10 thou cut, you will actually take 20 thou off the diameter of the part , right ?
    With a 30/60 triangle the opposite side is exactly half the length of the hypotenuse.
    So just swivel the compound to 30deg and whatever you set that dial to will come off the diameter.
    I don't have any trouble remembering to double the figure but it can be confusing so this might useful to someone.
    34
    1,080
    Further tip similar to that, setting your compound to 3 degrees off horizontal will give you a (near enough to) 10:1 diameter ratio (1 thou on the compound = one tenth on diameter) if you need really fine control.
  1. HSS Machining
    By Auskart in forum METALWORK GENERAL
    Last Post: 28th Oct 2016, 09:10 AM
  2. Looking for someone in Melbourne to do some machining for me
    By doug3030 in forum METALWORK GENERAL
    Last Post: 16th Dec 2013, 10:40 AM
  3. SOLD: Machining book"tabletop machining"
    By woodsurfer in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 7th Feb 2012, 06:52 PM
  4. machining stainless
    By Gavin Newman in forum METALWORK GENERAL
    Last Post: 17th Apr 2010, 01:12 PM
  5. Machining oil
    By Bodgy in forum METALWORK GENERAL
    Last Post: 23rd Apr 2008, 10:57 PM
