Results 1 to 15 of 25
Thread: Small hole bore gauge !
23rd Jun 2020, 11:36 PM #1
I've been considering the best way to measure small diameter bores. I know about gauge pins, but I was thinking bores from about 12 mm up to say 25 or 30 mm. Once I've got to 25 mm I can use my M&W inside callipers. But I've nothing that will fit into that gap in sizes.
I've done a drawing of a proposed device that I can use to accurately measure a small bore !
I have a pair of M&W 3" inch dividers that have very small diameter legs on them, so I thought that it might be a candidate for making a fitting that went onto the legs and be able to be inserted into a bore so that I could measure it using the transfer method, like I do with the external callipers.
I've a number of bits of scrap brass material that I can play around with.
I present the idea here in the hope that it will prove useful and of interest, and maybe collect some thoughts !Best Regards:
24th Jun 2020, 12:05 AM #2Gear expert in training
- 34
- 1,079
I'm all for finding a new project, but...you know these exist, right? https://www.justtools.com.au/moore-w...50mm-mw-315-01
24th Jun 2020, 02:25 AM #3Best Regards:
24th Jun 2020, 11:09 AM #4Most Valued Member
- Charlestown NSW
- 1,673
Baron.
If you are after a project you could look at making your own version of these.
peter
24th Jun 2020, 11:27 AM #5Golden Member
- Dec 2007
- 574
I've got a set of the telescoping gauges and also a set of expanding ball gauges - made you know where - I contemplated making them but once I priced up the raw materials I realised that the material cost is similar to a factory made set.
24th Jun 2020, 04:49 PM #6
Hi Peter, Guys,
Now those I did not know about ! They look interesting. Cheap enough as well.
From the picture they look to use a taper to open the measuring surfaces. I wonder just how sensitive they are.
I wasn't particularly looking for a project, more that I had a need to be able to measure a bore that I couldn't using gauge pins. Whilst 0.01 mm is good enough, my set only goes to 12 mm. From 25 mm and up I can use callipers.Best Regards:
24th Jun 2020, 08:18 PM #7Philomath in training
I swear by Interapid gauges like this one -
https://www.ebay.co.uk/itm/MACHINIST...sAAOSwswVa4QY2
Zero them out on the hole and then measure with a micrometer.
24th Jun 2020, 08:35 PM #8
24th Jun 2020, 08:52 PM #9Most Valued Member
- Healesville
- 2,129
https://www.ebay.co.uk/itm/Baty-1-2-...wAAOSw3g5eb9u2 and forget the shiraz
25th Jun 2020, 02:42 AM #10Senior Member
- Aug 2007
- 292
That's not how a telescoping gauge works. You open them until a little bigger than the hole you want to measure and then you lightly tighten the little knob. You put it in the hole and tip it through the hole once. It will centre as it passes through and push the ends in until through the smallest point and hold that dimension. When taken out of the hole you snug the little knob and then measure with your micrometer. The process does leave a visible mark in the hole, tiny scratch, but it shouldn't have any effect on the end use. This is one time you shouldn't buy a cheap set because the innards are often rough and don't slide past one another properly giving you no end of frustration and grief. Starrett or Mitutoyo are the go.
Pete
25th Jun 2020, 01:53 PM #11Most Valued Member
They also come in what I assume is called "half ball" for measuring shallow bores. I was going to suggest Baron reduce the 3mm on his drawing if he did a lot of shallow bores but given he whats to cover a greater range in one tool some of that 3mm will be used for larger holes(how much I haven't bothered to work out, not even sure I could)
https://www.ebay.com.au/itm/400645674784
If I needed a project I'd think about making one of these. Which sure look pretty handy though granted far more work. I have one but haven't had a need for it as yet so cant say how well they work.
https://www.flexbar.com/products/ind...al-groove-gage
In the past I've used the outside of a set of 3" dividers as is(cant have been that small a hole), it worked "well enough" lol. Your brass tips would have been a huge improvement
25th Jun 2020, 03:53 PM #12Senior Member
- Perth, Western Australia
- 67
- 362
I must commend you on making something like you are. Way beyond my capabilities.
For one or a few holes telescopic gauges are fine...
For lots of holes.
Mitutoyo are my preference but I do have some other name brands. That`s except for the red Chinese box. Some ass#$%^ liked the Mitutoyo more than me.
Tony
25th Jun 2020, 05:49 PM #13
Thank you very much four your notes and suggestions !
I've spent far too much time trawling the Internet looking at various types if bore measuring tools. I do like the Mitoyo direct reading bore gauge, way way out of my price range, at upto $4000 Us, I'll pass.
The split ball gauges are within my price range and would be favourite for two reasons. One they have a range from 3 mm up to 15 mm, two, they can take a reading against a flat at the bottom of a bore. This would be an advantage for me with me wanting to be able to measure inside a 55 mm deep hole.
These are the callipers that I propose to use for my tool. The tips I am making are intended to be push fitted on the sharp end of the points. These dividers I seem to have had forever, I went and bought a new pair about ten years ago, same M&W, same size, but the newer ones are far chunkier and the points far greater in diameter. These old ones are fine and delicate and the screw is a much finer thread.Best Regards:
26th Jun 2020, 04:38 AM #14Senior Member
- Aug 2007
- 292
On another forum a long time ago a guy wrote a spreadsheet that would calculate which 3 pins from a gauge pin set would be needed to measure a given hole size bigger than the set was made for. A 0.1000 to 0.5000 set would measure up to 1.0000 if memory serves. I found the discussion and tried the link to his website and got the 404 message. I suspect he is no longer around and the site was taken down. I don't have the spreadsheet anymore and couldn't run it on my Mac at the time but always thought it would be the cat's backside if it were an app. Then it would be accessible in the shop. Even tried to get a programer to write an app but it never happened. If anyone was so gifted as to know the math and be able to write another spreadsheet or even better an app I'm sure it would be appreciated.
Pete
26th Jun 2020, 03:24 PM #15Golden Member
- Dec 2011
- 505
Hi Pete,
Have you tried looking for the old web address on the internet archive https://web.archive.org/ ?
Bill
Depth Micrometer and Hole Gauge
By china eyes in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 18th May 2020, 06:34 AM -
Taper pin reamers, Bore gauge, Small hole gauges
By caskwarrior in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 24th Jun 2018, 06:31 PM -
Anyone able to bore out a pulley centre hole for me?
By Oddy in forum METALWORK GENERALReplies: 4Last Post: 23rd Mar 2016, 01:41 PM -
Looking for a small dial gauge
By jhovel in forum METALWORK GENERALReplies: 28Last Post: 30th Dec 2013, 04:41 PM -
Machining Advise: Small Production Run in PVC 21mm +/- 0.05mm Bore
By Jarh73 in forum METALWORK GENERALReplies: 5Last Post: 13th Jun 2012, 12:46 AM
