Results 1 to 13 of 13
Thread: Bridgeport Oil System Pipe
22nd Jun 2020, 08:29 PM #1Golden Member
- Apr 2019
- 596
The oil system pipes on my Bridgeport are brittle and snap when looked at. Is there a particular type of pipe I need to buy and an Australian source? I think it is 4mm OD and 0.8mm wall thickness or thereaouts.
22nd Jun 2020, 08:38 PM #2Gear expert in training
- 34
- 1,080
Would this stuff work? https://airless.com.au/air-equipment...nge-clear.html
22nd Jun 2020, 08:56 PM #3Most Valued Member
You could also look at Bundy tubing, which is what is used as brake tubing for trailers etc.
Set it up and never have to worry about it.
23rd Jun 2020, 08:30 AM #4Philomath in training
- 6,563
Have a talk to BL Shipway.
23rd Jun 2020, 09:55 AM #5Member
- Apr 2015
- Tungkillo, South Australia
- 87
- 74
I've got the same problem with my BP. US company H&W Machine Repair (www.machinerypartsdepot.com) have a kit but I can't seem to find it at the moment. They are always helpful and responsive if you email them.
Charles
23rd Jun 2020, 12:22 PM #6Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
BL Shipway should be able to sort you out.
23rd Jun 2020, 02:03 PM #7Golden Member
- Apr 2019
- 596
I did think of H&W but will find something local as it is only a low pressure oil resistent tube.
Cheers all
25th Jun 2020, 11:38 AM #8Golden Member
- Aug 2015
- Melbourne, Australia
- 843
Mk1_Oz, 4mm OD 2.5mm ID (clear) polyurethane tube - at least that is what it was for a UK built BP. The oilers are a different brand to the US ones, but hopefully they are the same size. I have some left over after my (UK) BP rebuild.
Figure out what length you need and PM me. Charles. Same. Let me know what you need.
Greg.
EDIT: FWIW, I am pretty sure this is it: https://au.rs-online.com/web/p/air-hose/9172407/. It was not stocked locally, it came from the UK in the end.
25th Jun 2020, 07:38 PM #9Golden Member
- Apr 2019
- 596
I will dig through my draws. Might even have something like that already. Cheers
27th Jun 2020, 09:25 PM #10Golden Member
- Aug 2015
- 843
Some info for Charles (PM's seem not to permit images and we were discussing oilers).
There are two different values of oil meters. Each is supposed to meter a given amount of oil to a specific place per oil pump. Parts and meterage shown here: https://www.machinerypartsdepot.com/...57/page/705249. On saddle / table dissasembly, note where each pipe goes. They have a 'memory' in shape so that helps, but, do them one at a time and put a label on the hose as you go.
If oil is not getting to its ultimate destination then there are multiple things to check:
* oil lines might be broken.
* The pump may not be working - which is easy to test - undo the outlet pipe, give it a pump and see what happens.
* The ends of the outlet pipes themselves may be clogged - especially the ones that go to the ways. Crud is kind of forced into the oil outlet hole from the ways and blocks the oil from coming out. That 'force' keeps pushing the crud back up the oil lines
* the oil meters may be blocked. Crud from either way may block them. The crud being 'forced' into the lines from the ways can actually work its way all the way back up to the meters.
In my case, it was all four of the above! )
The actual oil meters themselves are fairly robust and, if you're careful, can be dismantled and cleaned to be like new. It is not entirely obvious, but the oil meters are actually an assembly. The tops and bottom 'caps' are a press fit. Here are the only photos I have of the assembly. Sorry it does not show both caps. Not great pics, but you can see the parts and get the idea. Hopefully. Maybe.
I am going from memory here, so don't sue me if it is not quite correct.
At one end (under the cap) they have a threaded rod that I think limits the oil going through it. It does not thread into anything - it is just a tight fit in a bore, but the oil finds its way around the thread. The other end has a 'filter' ish .. subassembly inside of it. With a torch, if you look into the ends, you'll see which has the filter. The 'filter', if I recall, has small and fiddly stuff inside of it like a tiny spring and ball detent. I _think_ it controls the meterage - not 100% sure. You do not want to damage the filter.
To dismantle, you can put a small diameter punch in the end that has the threaded rod and knock stuff out the other end. If you choose the wrong end you'll ruin the small 'filter' that is in place. Ask me how I know.
When they get full of gunk and clog that filter and internal threaded rod then, without disassembly, a soak in <name you favourite solvent or fragrant bath salts> will likely have zero effect. Probably even a Carly Simon record will be powerless. I also sonic cleaned them in solvent - no cigar. Either replace, or dismantle and clean. You do not need to disassemble the filter sub-assembly. Soak it, clean it, blow it with air, etc etc.
All meters on my machine were clogged with gunk. If I recall, I ruined two learning how they came apart.
If your pump is working, a great way to test each meter is to screw the meter unit directly into the outlet port of the pump and give the pump a go - no oil = meter clogged. My pump output had the same thread as the meters so I figure this is usual.
Those oiler meters are like $25 AUD or so + postage, so, if you're careful, you can restore them and save a few bucks.
Hopefully that helps - feel free to ask questions, if I can help I will.
Greg.
<slurp>
28th Jun 2020, 09:47 AM #11Member
- Apr 2015
- 87
- 74
Thanks Greg, that was interesting. For some reason, I had thought the metering units were just crimped to impede the flow. I'll wait for warmer weather before having a go at my BP oil system.
Charles
1st Jul 2020, 06:57 PM #12Golden Member
- Apr 2019
- 596
Went to BL Shipway today and got some pipe. They only had 2 olives though so I might not be changing all the pipe just yet!
1st Jul 2020, 07:14 PM #13Golden Member
- Aug 2015
- 843
Good o. Well done. Something makes me think I reused my existing olives where I replaced pipe...
A need for inspiration on drive system
By chambezio in forum METALWORK GENERALReplies: 8Last Post: 27th May 2015, 09:24 AM -
Lubrication System
By simonl in forum METALWORK GENERALReplies: 89Last Post: 24th Aug 2012, 07:09 PM -
Pipe Vice-pipe bender identity and info please
By Log in forum METALWORK GENERALReplies: 18Last Post: 18th Apr 2012, 01:14 PM -
Coolant system
By jamie_c in forum THE HERCUS AREAReplies: 9Last Post: 18th Jan 2011, 12:14 AM -
bug in system?
By Farm boy in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 4Last Post: 13th Apr 2010, 12:38 PM
