Results 16 to 22 of 22
Thread: Drill press spindle runout fix
30th Jul 2020, 11:54 AM #16Member
- Aug 2016
- 80
Good suggestion, I hadn't thought of reversing it like that I'll try it tonight...........simple. The runout in the taper varies depending on the depth where it's measured so seems there is is angular misalignment, like it is bent. With a skewed socket, I expect to find a bend in the outer spindle but we shall see.
5th Aug 2020, 04:36 PM #17Member
- Aug 2016
- 80
Update: I checked the spindle outer between chuck and tailstock centre and it looks pretty straight. This lead me to discover that my 4jaw is not holding the spindle straight. Apparently this that is not unusual especially for older/used chucks. Anyway, looks like I'll need to use a steady and 4jaw to get it running as straight as possible. Having the steady on the bed makes setup/measuring at bit trickier though.
21st Aug 2020, 02:46 PM #18Member
- Aug 2016
- 80
For anyone interested, I re-bored the MT3 socket with the setup shown in the picture. First put the spindle in the 4jaw and trued it where the bottom taper bearing sits. Then I installed the steady at that point carefully to not disturb the setting. Then loosened the chuck, installed a ring of copper so the jaws wouldn't introduce skew and trued the chuck end. Results were pretty good, basically 0 runout in the spindle, all the remaining run-out is in the chuck + arbor. I didn't get the taper angle perfect but it seems close enough. I'm happy with it now since I don't have the work piece dancing around with large drill bits.
Attachment 388209
21st Aug 2020, 02:53 PM #19Golden Member
- Dec 2007
- 574
That's good news that you've fixed it to your satisfaction, it feels good to have a winner.
23rd Aug 2020, 09:05 AM #20Golden Member
- Aug 2015
- Melbourne, Australia
- 843
Fantastic you got a result. Well done. Not sure if it is me, but there is no pic and the attachment link says it is invalid.
23rd Aug 2020, 03:40 PM #21Diamond Member
- N.W.Tasmania
- 1,407
I'm really too late to this thread, but for anyone interested Tom Lipton has a series of about 4 videos on setting up to cut a short taper, and he actually references the quill a drill press. It is worth anyones time in looking over the videos, let alone those of us short on machining experience, so here is the link to the first in the series. https://www.youtube.com/watch?v=OfrRFCzGNTw. Plenty to learn even if you do have your drill performing as you want. Cheers,
Rob
23rd Aug 2020, 07:18 PM #22Member
- Aug 2016
- 80
Strange, the picture was working. Now it's not working for me either. I'll insert it again
Sterling/ Richardson drill press spindle
By china eyes in forum METALWORK - Machinery, Equipment, MARKETReplies: 20Last Post: 8th Sep 2023, 10:28 PM -
Sterling Drill Press Spindle
By china eyes in forum WANTED TO BUYReplies: 18Last Post: 10th Nov 2018, 09:39 PM -
Drill Press Runout
By chambezio in forum METALWORK GENERALReplies: 8Last Post: 4th Nov 2016, 03:28 AM -
Can The Spoke Section Diameter Of A Drill Press Spindle Be Reduced By 0.2mm
By thumbsucker in forum METALWORK GENERALReplies: 9Last Post: 12th Aug 2015, 11:27 PM -
Richarson drill press spindle
By chalmers888 in forum METALWORK GENERALReplies: 9Last Post: 24th Apr 2013, 10:16 PM
