Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Aug 2016
    Adelaide
    80
    Quote Originally Posted by familyguy View Post
    I may be wrong but it seems to me that as long your spindle is not bent and it is only the morse socket that is damaged then the 4 jaw setup should be ok to use. Are you able to set the large end up in a 4 jaw to run true, griping it a few mm from the end and not too tight with the spline end supported by a centre in the tail stock, this should give you a good idea if it is bent.
    Good suggestion, I hadn't thought of reversing it like that I'll try it tonight...........simple. The runout in the taper varies depending on the depth where it's measured so seems there is is angular misalignment, like it is bent. With a skewed socket, I expect to find a bend in the outer spindle but we shall see.
  2. #17
    Aug 2016
    Adelaide
    80
    Update: I checked the spindle outer between chuck and tailstock centre and it looks pretty straight. This lead me to discover that my 4jaw is not holding the spindle straight. Apparently this that is not unusual especially for older/used chucks. Anyway, looks like I'll need to use a steady and 4jaw to get it running as straight as possible. Having the steady on the bed makes setup/measuring at bit trickier though.
  3. #18
    Aug 2016
    Adelaide
    80
    For anyone interested, I re-bored the MT3 socket with the setup shown in the picture. First put the spindle in the 4jaw and trued it where the bottom taper bearing sits. Then I installed the steady at that point carefully to not disturb the setting. Then loosened the chuck, installed a ring of copper so the jaws wouldn't introduce skew and trued the chuck end. Results were pretty good, basically 0 runout in the spindle, all the remaining run-out is in the chuck + arbor. I didn't get the taper angle perfect but it seems close enough. I'm happy with it now since I don't have the work piece dancing around with large drill bits.
    Attachment 388209
  4. #19
    Dec 2007
    Adelaide
    574
    That's good news that you've fixed it to your satisfaction, it feels good to have a winner.
  5. #20
    Aug 2015
    Melbourne, Australia
    843
    Fantastic you got a result. Well done. Not sure if it is me, but there is no pic and the attachment link says it is invalid.
  6. #21
    Oct 2008
    N.W.Tasmania
    1,407
    I'm really too late to this thread, but for anyone interested Tom Lipton has a series of about 4 videos on setting up to cut a short taper, and he actually references the quill a drill press. It is worth anyones time in looking over the videos, let alone those of us short on machining experience, so here is the link to the first in the series. https://www.youtube.com/watch?v=OfrRFCzGNTw. Plenty to learn even if you do have your drill performing as you want. Cheers,
    Rob
  7. #22
    Aug 2016
    Adelaide
    80
    Strange, the picture was working. Now it's not working for me either. I'll insert it again
  1. Sterling/ Richardson drill press spindle
    By china eyes in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 8th Sep 2023, 10:28 PM
  2. Sterling Drill Press Spindle
    By china eyes in forum WANTED TO BUY
    Last Post: 10th Nov 2018, 09:39 PM
  3. Drill Press Runout
    By chambezio in forum METALWORK GENERAL
    Last Post: 4th Nov 2016, 03:28 AM
  4. Replies: 9
    Last Post: 12th Aug 2015, 11:27 PM
  5. Richarson drill press spindle
    By chalmers888 in forum METALWORK GENERAL
    Last Post: 24th Apr 2013, 10:16 PM
