Results 1 to 15 of 22
Thread: Need help with new mill perchase
17th Jun 2020, 10:47 PM #1Novice
- Jun 2020
- Hustonville, Kentucky
- 74
- 20
I am looking at purchasing either a Precision Matthews PM727V or a Weiss VM32L. I can find plenty of reviews on Precision Matthews and the PM727V, but not very much on Weiss or the VM32L. I have owned a Excello knee mill, but have moved and only have room for a bench mill. It will go in my basement. I will have to take it apart as I do not have an outside entrance. Any help will be greatly appreciated.
17th Jun 2020, 11:46 PM #2Senior Member
- Oct 2015
- melbourne
- 473
I suspect you won't get a lot of direct assistance here. We welcome everyone but most of us live in Australia with a very limited range of toys machines to select from...
17th Jun 2020, 11:49 PM #3Most Valued Member
- Healesville
- 2,129
18th Jun 2020, 08:34 AM #4Most Valued Member
I can't help either but I do wish you luck with your search.
Also I'd be keen to see some pics of your basement workshop.
18th Jun 2020, 11:26 AM #5Golden Member
- Dec 2007
- 574
I googled the machines and if google is correct they either are or are very similar to the Seig/Optimum style machines, I wouldn't be surprised if Precision Matthews and Weiss machines are sold here in Australia but under a different name, the Weiss looks almost the same as an Optimum, I don't have one myself so I can't comment on what they are like.
19th Jun 2020, 03:14 AM #6Novice
- Jun 2020
- 74
- 20
19th Jun 2020, 03:15 AM #7Novice
- Jun 2020
- 74
- 20
19th Jun 2020, 03:20 AM #8Novice
- Jun 2020
- 74
- 20
I am just getting started, all I have down there now is a work bench and a small drill press. I lucked up yesterday and found a Jet BD-920N lathe for $300.00. It did not have much tooling with it, but I have already made some bushings with it. I will have to take it apart to get it in the basement. I will post some pictures when I get the time.
19th Jun 2020, 03:21 AM #9Novice
- Jun 2020
- 74
- 20
19th Jun 2020, 08:03 PM #10
There are an awful lot of machines that are basically copies of the Optimum / Wiess / PM machines. I have a Chinese copy of an Optimum BF20L, for all intents and purposes its an Optimum in everything but name. Even the same parts list.
But the quality of the machines varies tremendously !Best Regards:
20th Jun 2020, 11:17 AM #11Novice
- Jun 2020
- 74
- 20
20th Jun 2020, 04:21 PM #12
Hi Mec9900, Guys,
The PM (Precision Matthews) machines are Chinese copies of the German Optimum ones. They will have some small variations between them, done to prevent copyright issues. After that its down to price, how much you are prepared to pay. Few people will be honest enough to say that their machine is rubbish. I've done a lot of work with mine and made many modifications, but I bought what I could afford at the time. Whilst the supplier paid lip service to any 3 year guarantee, any claim was subject to an actual manufacturing defect that couldn't be put down to misuse.
As an example, my machine from new had a slight knock that varied with speed. I originally thought that it was just newness and would run in. Then I had a slitting saw nip in an aluminium work piece ! That damaged the teeth on the plastic gears. At that point I didn't even know that the gears were plastic.
The replacement gear was very expensive item. I then replaced the plastic gears with steel ones, it wasn't until I did this that I discovered that the plastic gear had the bore machined slightly off centre and that it was this that caused the knock. The supplier didn't want to know, as far as they were concerned it was all my fault for misusing the machine.Best Regards:
21st Jun 2020, 07:11 AM #13Novice
- Jun 2020
- 74
- 20
21st Jun 2020, 05:47 PM #14
22nd Jun 2020, 10:54 PM #15Novice
- Jun 2020
- 74
- 20
Hercus o mill Vertical mill head lubrication
By china eyes in forum THE HERCUS AREAReplies: 0Last Post: 14th Oct 2018, 06:57 AM -
Selecting a small Mill / Mill/Drill
By Wombat200 in forum METALWORK GENERALReplies: 31Last Post: 15th Mar 2012, 10:58 PM -
Arboga EM825 mill vs Hercus model 0 mill?
By neksmerj in forum METALWORK GENERALReplies: 23Last Post: 14th May 2011, 03:16 PM -
Face Mill V End Mill
By eskimo in forum METALWORK GENERALReplies: 8Last Post: 31st Aug 2010, 03:19 AM -
