Results 1 to 15 of 16
Thread: Bandsaw swarf brush
17th Jun 2020, 04:47 PM #1Most Valued Member
- 4,258
Bandsaw swarf brush
My old Porsche metal bandsaw has a small wire brush for removal of swarf from the blade.
These are no longer available and to fit one I would need to adapt the round wheel ones that are now being fitted.
Did some thinking and recalled the bandsaw at the steel outlet which had cutting fluid nozzle after cutting.
Some others on another forum said that they have done this also and supposedly works a treat.
So I fitted one today.
17th Jun 2020, 05:13 PM #2Member: Blue and white apron brigade
Here's my baby BS fore and aft coolant.
17th Jun 2020, 05:26 PM #3Most Valued Member
- 4,258
17th Jun 2020, 11:06 PM #4Senior Member
- Perth, Western Australia
- 67
- 362
I added a second fluid line to mine. Also changed the worn fixed wire brush to wire wheel. The blade now stays a lot cleaner.
Tony
18th Jun 2020, 08:40 AM #5Most Valued Member
Hi Tony, this is something I need to do for my BS too. Does that round wire brush rotate during operation?
18th Jun 2020, 09:21 AM #6Senior Member
- 67
- 362
18th Jun 2020, 10:17 AM #7Member: Blue and white apron brigade
18th Jun 2020, 05:25 PM #8
I use a piece of carpet felt glued to the back mount. I just cut a slit in the felt with a Stanley knife and let the blade run through it. It collects the swarf and keeps the blade clean ! Actually the more swarf it collects the cleaner the blade is. I just brush the collected swarf off now and then. However I don't use coolant.Best Regards:
18th Jun 2020, 10:19 PM #9Golden Member
- Dec 2011
- 505
18th Jun 2020, 11:23 PM #10Most Valued Member
- 2,672
I'm sure BaronJ is probably either having his afternoon nap or busy with the honeydo list at this time of day so I'll take the liberty of replying
I'd say he means carpet underlay felt - the older style underlay that isn't rubber/foam.
Like this
https://www.homeupholsterer.com.au/h...x-backing.html
It was still commonly used in cars after most domestic underlay moved over to rubber/foam. My old late 90's falcon still had it, whereas I only ever recall using the rubber style in the late 70's when I did a bit of work with the carpet layer next door.
19th Jun 2020, 09:52 AM #11Most Valued Member
- 4,258
I was thinking about this yesterday or very similar anyways
Have the blade run though two adjustable insertion rubber wiper blades...one iether side of the blade..?
but for now I will just wait till i need to saw up steel and inspect as to how well the extra cutting fluid nozzle worked....dont want to fit another swarf brush or do anything at this stage until I have monitored it
20th Jun 2020, 03:16 PM #12Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Hi eskimo,
I tried a variety of brush set ups on my band saw and found they did not last long before they wore out. In the end I used a piece of the black poly tubing used for water irrigation. You need to find a piece the right internal dimensions to slip over your current coolant outlet and cut it long enough to fit down over your blade, you will have make a cut longitudinally and in the center of the poly pipe with a hack saw the same length as the blade width. Once this is in place the poly tube will deflect most of the swarf and the coolant flow will take care of the rest and lubricate the blade. I only have a single coolant supply on my saw mounted just after the cut and it works.
Bob
20th Jun 2020, 04:59 PM #13Most Valued Member
- 4,258
Just finished cutting some largeish bits of steel.
It has worked better than I thought it would.
Next to nothing in the way of swarf inside the arm and wheels.
Will now need to make a splash gaurd for new nozzle to stop cutting fluid splashing onto floor.
Sheesh...make something to fix something only to find you have make something else to fix what you just done...lol
20th Jun 2020, 08:55 PM #14
Some pictures of my bandsaw blade wiper...
It is a piece of 5 mm thick carpet felt.
The felt is simply stuck on with a dab of Bostik. Its been on there since I refurbished the bandsaw, which is several months now. The debris simply collects where the blade runs through, I just brush it off now and again.
This is the carpet felt that I used. I bought a 20 metre long roll of it when I did my camper van conversion. I used it to line all the surfaces.Best Regards:
21st Jun 2020, 07:46 AM #15Most Valued Member
That's a simple but very effective method.
Like it.
Swarf Containment
By Anorak Bob in forum METALWORK GENERALReplies: 6Last Post: 13th Nov 2018, 10:06 AM -
swarf
By leroy in forum METALWORK GENERALReplies: 20Last Post: 24th Nov 2016, 08:43 PM -
What do you do with your swarf?
By Gestalt in forum METALWORK GENERALReplies: 27Last Post: 31st May 2016, 12:20 AM -
Swarf filter
By morrisman in forum METALWORK GENERALReplies: 17Last Post: 9th Dec 2013, 07:36 AM -
Swarf & Motors
By toolman49 in forum METALWORK GENERALReplies: 4Last Post: 28th May 2011, 11:01 PM
