Results 31 to 38 of 38
Thread: Cutting tool question
19th Jun 2020, 03:45 PM #31Gear expert in training
- 34
- 1,079
I would have thought that you'd want the cutting force directed down into the bed, rather than up into the toolpost screws... I'm also not understanding how parting upside down is less stressful on the machine, could you explain?
19th Jun 2020, 07:24 PM #32
Hi Brian,
Thank you for your post !
Hey don't apologise ! I didn't realise that the Eccentric parting tool was intended to be used in the front tool holder.
My thoughts were "screw on chuck, blade jamming", particularly after having seen someone having a parting blade jam and the chuck unscrewing and the amount of damage that it did.Best Regards:
19th Jun 2020, 08:37 PM #33Most Valued Member
- 4,890
In their blurb they state to use it in the normal way if using a threaded spindle.
19th Jun 2020, 10:08 PM #34Most Valued Member
- Charlestown NSW
- 1,673
With all this talk of various tools holding methods, in regard to shims for packing, an old style (can type) car coil is a good source of small, thin steel shims. Great for small tool holders or tool posts.
Something else that no one has mentioned either is never throw away your broken centre drill stubs. They are great for making small, special tools. Its a lot easier to make a round hole than a square one.
peter
20th Jun 2020, 02:52 AM #35
Its surprising what good use bits of broken HSS can be put to ! I've collected a fair bit over the years. The most useful use has been in the fly cutter that I made. It is my go to milling tool, very handy for using those bits that would otherwise get thrown in the scrap bin.Best Regards:
12th Jul 2020, 07:24 PM #36Member
- Apr 2020
- Ettalong Beach NSW
- 62
- 72
Update
Just thought I'd fill you in on what I decided.
From LPRtools I bought a straight holder and a couple of 1/4" HSS blanks. I was encouraged by the support in this thread and did my first grind today.
I ended up buying an 8 inch bench grinder and a white aluminium oxide wheel. My goodness! What a difference it made to grinding! I could never work out why I did such a crap job in my attempts at sharpening drills. Now I know.
Ironically, the multiple nylon bushes that comes with the grinding wheel are loose enought to make the wheel wobble. So I used the wheel to grind the HSS tool so I could turn a single bush to stabilise the wheel. I can see how the hobby of machining creates its own needs to perpetuate itself.
Cheers.
12th Jul 2020, 07:48 PM #37Most Valued Member
- 2,671
Good to hear its going well, and thanks for reporting back with the progress.
If you haven't already noticed, while the white wheels are great they are also really soft (which is why they work so well) so its easy to wear a groove in them. If you haven't already got one pick up a cheap wheel dresser to use when you really need a flat wheel. One of the single point diamond ones from the land of COVID works fine for me but there are other options such as abrasive sticks or the Tee shaped ones covered with lots of smaller diamonds. Generally I find I can keep the wheel flat enough for most things just by working the different parts of the wheel as you grind so that it wears evenly.
12th Jul 2020, 09:05 PM #38Member
- Apr 2020
- 62
- 72
Thanks for that, I should have added that I did buy a diamond wheel dresser as well. Got a decent one from Carbatec. 'Tee shaped ones covered with lots of smaller diamonds.'
Mist Cooling / Cutting Lubrication Question ..... ?
By RoyG in forum METALWORK GENERALReplies: 32Last Post: 9th Jul 2016, 08:28 PM -
External thead cutting tool
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 8th Dec 2011, 07:32 PM -
Which Tool for cutting sheet metal
By squigs in forum METALWORK GENERALReplies: 16Last Post: 9th Aug 2011, 11:06 PM -
water cutting steel question
By 2zenmonks in forum METALWORK GENERALReplies: 3Last Post: 21st Mar 2011, 06:39 PM -
16 DP Gear Cutting Tool
By electrosteam in forum METALWORK GENERALReplies: 17Last Post: 5th Oct 2010, 05:35 PM
