Results 1 to 10 of 10
Thread: Stuck keyless chuck
8th Jun 2020, 04:25 PM #1Senior Member
- Oct 2010
- NSW
- 181
Stuck keyless chuck
I'm sure I've seen this question asked before but I can't find it with a search. I can't undo my keyless chuck - it has overtightened.
What I did find while searching was, many moons ago member Ueee, saying never use a hole saw in a keyless chuck - guess what I did.
I've done it before and never had a problem but this time it's stuck tight.
Anyone got a removal method that's worked for them.
John
8th Jun 2020, 04:43 PM #2Senior Member
- Oct 2010
- NSW
- 181
Don't panick - problem solved
I went back to the shed and found a way to stop the drill press spindle from turning - a wedge from a piece of wood - and with both hands on the chuck it came free.
8th Jun 2020, 04:50 PM #3Senior Member
- Perth, Western Australia
- 67
- 362
Crude but effective.
Tony
8th Jun 2020, 05:23 PM #4
Hi John, Guys,
That is one reason that I don't like keyless drill chucks ! Do anything to cause the jaws to twist tends to lock them up.Best Regards:
8th Jun 2020, 06:28 PM #5Member: Blue and white apron brigade
Two rubber strap wrenches works a treat. All my chucks have holes that fit a standard ER32 collet chuck key so I only need one rubber strap wrench. I keep an ER32 key attached to my DP on a length of SS cable as I can usually use one of these and a hand to get them undone.
8th Jun 2020, 06:41 PM #6Senior Member
- Sep 2019
- Newcastle, AU
- 238
+1 for strap wrenches... I had no end of trouble with keyless chucks and my hands not being strong enough to get the bits back out, enough to send me back to keyed chucks as I can more easily get leverage on the chuck keys.
8th Jun 2020, 07:12 PM #7Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
i normally hold the tang in the vice and use a chain whip on the body. It happens quite often at work, i haven't managed to train the boilermakers, not to use holesaws in the keyless chucks.
8th Jun 2020, 07:22 PM #8Senior Member
- 67
- 362
I cannot remember the last time I used a keyed chuck.
Interesting mentioning strap wrenches. I have been pulling some bits and pieces out of my work boxes that have been sitting on the garage floor for the last 18 months.
My two oil filter straps were ones I pulled out and hung on the wall for latter use. I did not even think of using them for the rare times the chucks jam even though I have used at work for similar things.
I am just becoming to brutal in my old age.
Tony
8th Jun 2020, 07:41 PM #9Senior Member
- Dec 2010
- Syd
- 492
A friend decided to use my Albrecht chuck with a 4" holesaw, mushroomed and cracked one of the components - of course this one was modular with the arbor and non-repairable. Brings a tear to the eye the replacement cost!
8th Jun 2020, 08:36 PM #10Most Valued Member
We have a keyless chuck at work on a DP, the bottom knurled ring tightens the jaws onto the drill bit, while the top knurled ring locks the bottom. One of the neanderthals there, tightens them both up so tight, that BTS's tool are required.
Stuck chuck ....
By morrisman in forum METALWORK GENERALReplies: 46Last Post: 29th Jul 2015, 09:37 PM -
Keyless Chuck for Lathe & Mini Mill
By Jim Ferrous in forum METALWORK GENERALReplies: 10Last Post: 2nd Nov 2013, 10:51 PM -
R8 arbor and keyless chuck
By morrisman in forum METALWORK GENERALReplies: 7Last Post: 15th Nov 2011, 10:40 PM -
JT33 keyless chuck?
By nadroj in forum METALWORK GENERALReplies: 13Last Post: 10th Apr 2011, 07:41 PM -
Keyless Chuck Advice??
By RossM in forum METALWORK GENERALReplies: 0Last Post: 27th Dec 2010, 05:08 PM
