Results 16 to 30 of 113
4th Jun 2020, 11:55 AM #16Golden Member
- Aug 2015
- Melbourne, Australia
- 843
Bob. re the tag. I'll take it!! Thank you.
If I do end up actually making them then I'll send it back. But thanks. Very generous.
Yet another beer I owe you I would say.
4th Jun 2020, 12:19 PM #17.
- 6,459
Greg,
The McPherson's catalogue of 1960 shows Waldown drills with the abreviated cast iron belt guard, the '66 catalogue shows the drills with the pressed steel guards fully enclosing the pulleys and belts. The '66 catalogue also includes an illustration of the 2M which did not appear in the earlier publication.
My drill is the 3 Morse version of the 2 Morse-ed 2M hence the enlarged spindle nose. The heavier construction of the 2/3M allowed the provision of the larger spindle taper but I reckon the best feature of the 2/3M is the over centre belt tensioning device.
Rest assured, my drill did not look like it does now when I bought it. It had the mandatory porch paint overcoat in dribbled hammertone green. Apart from the repaint, the best thing I did for the Waldown was to replace everything I could with stainless steel.
And yes, they are oil holes.
Send me your new postal address.
Bob.
4th Jun 2020, 12:40 PM #18Golden Member
- Aug 2015
- 843
Thanks Bob,
Oh man - that belt tensioning device is sweet!!
4th Jun 2020, 03:05 PM #19Senior Member
- Feb 2014
- Werribee, Melbourne
- 178
Greg, I have no idea what these came off as I got them in a box of junk that came with my Seneca Falls lathe years ago but they appear to be 4-step A section pulleys from a drill press.
The steel one looks to be 9/16" bore with 1/4" keyway and the alloy one is a plain 3/4" bore.
Unfortunately the alloy one has been modified on the outermost large flange so is probably only good for taking dimensions.
If they are of any use to you they are yours.
4th Jun 2020, 03:10 PM #20Golden Member
- Aug 2015
- 843
Thanks very much Ray, appreciated. I'll measure up some Waldown ones tonight (hopefully) and also the motor shaft / key and splined spindle thing setup I have to get a starting point. If I can use one or two of those, I'll sure snaffle them for sure. Thanks.
4th Jun 2020, 06:01 PM #21Most Valued Member
- 4,890
May be able to supply a complete tapping machine for $250.00 if interested.
4th Jun 2020, 06:07 PM #22Golden Member
- Aug 2015
- 843
hey pipeclay,
Feeling all ignorant here. I'm not sure what you mean. You mean for parts?
4th Jun 2020, 06:34 PM #23
4th Jun 2020, 08:32 PM #24Most Valued Member
- 4,890
4th Jun 2020, 08:50 PM #25Gear expert in training
- 34
- 1,080
I'm lost as well....how did we get from drill rebuild to tapping machine?
5th Jun 2020, 10:37 AM #26Golden Member
- Aug 2015
- 843
pipeclay - thank you. very kind of you. I'll see how I go.
I've done some measuring on pulleys, so if I need to I can make those. I've not yet compared them with the 5 speed ones I have - to compare speed ranges - like, maybe the min speed of the 5 speed range is like 800 or something coz they came off something with a 6 pole motor - who knows. I'll check later.
I also managed to snaffle a table in better condition than mine. Pics to follow.
Greg.
5th Jun 2020, 06:33 PM #27Most Valued Member
5th Jun 2020, 07:12 PM #28Most Valued Member
- 4,890
Yes the machine is complete,there are some photos on here somewhere or Bob Thomas might have some that I sent to him.
If you can't find them let me know and I will take some more, machine at present located in Cowra 2794.
5th Jun 2020, 08:52 PM #29
Greg,
If you found my resto of my SIL's Waldown 8SN, you can see the mounting of the centre pulley. It is an excentric poivot in the top of the post bore.
The pulley holds two bearings. The excenter in held (and clamped) with a single bolt into the side of the main casting into a groove, which also stops the excenter from falling in or slipping out upwards.. To change the belts, just loosen the bolt, change the belts and pull them tight. The excenter finds its own position and you can then clamp it - or not. It works well and give you lower speeds. Your second pulley with the very large bore may be that center pulley. If not, it makes a great candidate for boring recesses for the two bearings.....
Give me a call any of this needs clarification.Cheers, Joe
5th Jun 2020, 10:57 PM #30Golden Member
- Aug 2015
- 843
Gudday Joe - someone else I owe beers to no doubt! I hope you and the good lady are well mate.
I am pretty sure this old girl is the two pulley model - so no centre pulley. But .... got a link to your thread? I can't recall seeing those pics.
Greg.
Waldown drill press.
By stix012 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 19th Nov 2018, 10:35 AM -
Jones and shipman boat anchor
By welder in forum METALWORK GENERALReplies: 6Last Post: 10th Mar 2017, 09:18 PM -
Waldown Drill Press Mods
By Petip in forum METALWORK GENERALReplies: 7Last Post: 5th Jul 2015, 01:34 PM -
Waldown drill press
By eskimo in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 10th Sep 2014, 10:55 AM -
Waldown Drill Press
By KevM in forum METALWORK GENERALReplies: 24Last Post: 1st Sep 2011, 01:31 AM
