Results 1 to 10 of 10
Thread: Graduated Rod/Bar
1st Jun 2020, 12:20 AM #1Golden Member
- Jun 2005
- Helensburgh
- 618
Graduated Rod/Bar
Thsi is a long shot, does anyone know where I could buy a graduated rod/bar/shaft at least 300mm long. This marking guage has one as an example of what I am after though it does not have to be round, I thought of using a 300mm rule but it most probably not rigid enough.
Edit: OOOOOPPPS https://www.ebay.com.au/i/2935871046...iABEgLfV_D_BwECHRIS
1st Jun 2020, 04:30 AM #2Most Valued Member
- 2,651
The only graduated bar I can think of is the likes of a drill press quill stop or saw guide but they generally aren’t that long and likely not cheap to buy as a spare.
Could you glue a 300mm rule onto a heavier piece of bar?
1st Jun 2020, 10:20 AM #3Member: Blue and white apron brigade
- 7,183
Some Starret and German rulers come in 2mm thickness which makes them quite rigid but I think they are at least 1m long and cost an arm and a leg.
A 300mm (non-digital) depth vernier calliper can be bought on ebay for about $30
https://www.ebay.com.au/itm/High-Qua...-Ty-b6UKU9jOvA
Cheap 300 mm Digital ones can be had for about $40, I bought one of these a few years ago and compared it to a Mitzi I borrowed from the place where I used to work and it agreed very well.
1st Jun 2020, 10:20 AM #4Golden Member
- Jun 2005
- Helensburgh
- 618
I have thought about putting a rule on a backing pice, Moore & Wright do a narrow 300mm rule that might be suitable. Does anyone know if a laser could put graduations on a rod or bar?
CHRIS
1st Jun 2020, 12:16 PM #5Most Valued Member
- 4,887
Probably easier to do it on a mill , if only after graduations.
1st Jun 2020, 12:23 PM #6Golden Member
- Jun 2005
- Helensburgh
- 618
300 mm marks on a mill, that could take some time I guess but I will ask my toolmaker Brother in Law what he thinks.
CHRIS
1st Jun 2020, 02:28 PM #7Intermediate Member
- Aug 2009
- Lara, Vic, Oz
- 46
If you just wanted say 1mm marks I guess you could set up a bar in the lathe, slightly offset from centre, and screwcut with the appropriate pitch so that you are only cutting a short arc of the thread. Be difficult to do major divisions though.
1st Jun 2020, 06:30 PM #8Gear expert in training
- 34
- 1,075
What about a combination square rule? No rigidity issues on those
2nd Jun 2020, 09:07 AM #9Most Valued Member
- Charlestown NSW
- 1,669
Whats the application?
peter
2nd Jun 2020, 03:09 PM #10
Hercus large graduated dials?
By neksmerj in forum THE HERCUS AREAReplies: 6Last Post: 22nd Jan 2016, 10:09 AM -
Graduated Circumfral markings
By DSEL74 in forum METALWORK GENERALReplies: 14Last Post: 28th Nov 2015, 01:14 PM -
Graduated Adjustment Dials
By localele in forum METALWORK GENERALReplies: 4Last Post: 15th Dec 2012, 06:40 AM -
Knurled Screws for Graduated Dials
By Abratool in forum THE HERCUS AREAReplies: 73Last Post: 18th Jun 2012, 11:54 PM -
Schaublin Mill Graduated Scales
By Anorak Bob in forum METALWORK GENERALReplies: 0Last Post: 10th Dec 2010, 09:32 PM
