Results 16 to 29 of 29
2nd Jun 2020, 07:01 PM #16
I have come across some peg board (metal type) that is a bit ratty, but will scrub up OK. I have also spotted a 104pc assortment of hooks etc for said pegboard on ebay, for under 30 bucks... so way better than the bunnings offer of 2 hooks for 6 bucks.
2nd Jun 2020, 08:05 PM #17Member: Blue and white apron brigade
- 7,183
The problem with sets (as I found out) is that one ends up only finding uses for half of the hooks.
BTW Bunnings as a 47 piece set for $15 including a neat rack for open ended spanners.
https://www.bunnings.com.au/zenith-z...-pack_p3966089
2nd Jun 2020, 09:19 PM #18Most Valued Member
- Healesville
- 2,129
I am a bit short on wall space, I have a sidchrome wall unit type tool cabinet that is bolted to an A frame that is on castor wheels
It has a home made shadow board below that and a shelf below that. It is handy as it can be put where ever you are working and
pushed out of the way also if need be.
3rd Jun 2020, 07:17 PM #19Senior Member
- Sep 2009
- Newcastle
- 341
Rare earth magnets work great for tools like double open ended spanners.
3rd Jun 2020, 09:46 PM #20Member: Blue and white apron brigade
- 7,183
Not really sure about magnets. They tend to magnetise the tools and then swarf sticks to them too much for my liking.
3rd Jun 2020, 10:09 PM #21Senior Member
- Perth, Western Australia
- 67
- 362
4th Jun 2020, 08:03 PM #22Diamond Member
- Jun 2010
- Canberra
- 1,322
Now I've cleaned up the area where I want to re-setup a workbench and tool wall, with all the junk removed I've realised it's actually a pretty substantial area - this is the 2400 wide bay where the workbench will go:
Current plan is to hang 1800x1200 17mm formply vertically between the purlins at the back, then use shelf rails to make the benchtop. Still tossing up what to do on the back wall in terms of pegboard, shadowboard etc., but I'm realising there's a lot more wall space than tools to hang there (this is a very lightly-equipped workshop).
This is the bay to the left - I'm thinking of leaving this clear of any more shelving with a view to putting a bench grinder and drill press there. Will put up some formply at the back there too.
This leftmost bay is how the other two were originally set up, with a bench at about 900 - the others had shelves below, all covered in masses of junk.
8th Jun 2020, 07:21 PM #23
Sideways pic strikes again.
Anyway, got this mounted. Old retail hanging stands. Just screwed to the wall supports like a true chippy.
Will shop for some pegboard pegs in the coming days.
14th Jun 2020, 08:28 PM #24Diamond Member
- Jun 2010
- Canberra
- 1,322
This is where I'm up to:
Formply is up, I've put a few shelving rails back in place, there's a bunch more, so I can add shelves below the bench, but at 600 deep I've found that you're not really using the full depth, so tossing up what to do there.
Also need to mount this Record No. 5 vice:
It used to be in the middle of the bench. Tossing up if it might be better mounted to the left end of the bench, closer to the blue column.
Bunnings flog an 1800x410 metal pegboard that I'll put up and then work out what to put on it.
Sparky should be around in the next day or two to run 2 circuits - one for all the 10A GPOs and one for a 15A GPO.
14th Jun 2020, 09:30 PM #25
This sideways pic thing really rustles my jimmies.
Turns out the cheap-o (free) peg board I used has 25mm spacing... but over a span of a 300mm or so, it goes a bit awol. So I have drilled off the spot welds on the screwdriver holder and the flat parts tray, and installed them with new properly spaced holes and push rivets.
Getting way more organised now.
14th Jun 2020, 11:28 PM #26Senior Member
- 67
- 362
Good progress being made there.
I your like me constant adjustments will be made. 15 years mine has been up and I am still tweaking.
Tony
15th Jun 2020, 09:06 AM #27Member: Blue and white apron brigade
- 7,183
Thi morning I started to read the forums without my glasses on. The title of this thread looked like "Well HungTool storage . . . .. "
15th Jun 2020, 06:41 PM #28
The innuendo was there from the beginning.
Re-read the first line of the first post
21st Jun 2020, 06:49 PM #29Most Valued Member
- 4,255
Looking For Tooling Storage Ideas.
By wm460 in forum METALWORK GENERALReplies: 21Last Post: 30th Sep 2018, 11:53 AM -
Any ideas for Multifix tool holder storage / rack ?
By johntopp in forum METALWORK GENERALReplies: 12Last Post: 24th Dec 2015, 06:22 AM -
Engineering ideas needed for a gardening task
By neksmerj in forum METALWORK GENERALReplies: 2Last Post: 25th Jun 2015, 09:12 PM -
Change gear storage suggestions needed
By Michael G in forum METALWORK GENERALReplies: 9Last Post: 11th Jun 2013, 08:59 PM -
Post Drivr Ideas Needed
By Oldneweng in forum METALWORK GENERALReplies: 13Last Post: 9th May 2012, 10:01 PM
