Results 1 to 15 of 17
Thread: 1095 Spring Steel were are you.
28th May 2020, 07:49 PM #1
1095 spring steel were are you.
I’m having no luck trying to find 1095 spring steel in Australia at .5 mm or there about in thickness.
I can get 1095 in thicker sections ie 1/8 3 mm.
But no luck under that.
I’ve contacted a few Knive making suppliers, a few of the bigger metal companies.
No luck either.
I know it’s available overseas ,especially the US ,but I would need to sell a kidney for the postage and exchange rate at present.
I’m wanting 1095 by .5 mm for making handsaws (for wood the softer metal lol )
It is sometimes packaged as 1095 shim stock in rolls blue tempered.
I would be happy with a roll of that.
Anyone know of any local suppliers ?
Cheers Matt.
28th May 2020, 11:52 PM #2Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
29th May 2020, 11:10 AM #3Member
- Apr 2015
- Tungkillo, South Australia
- 87
- 74
These might have something useful for you: https://www.smallparts.com.au/store/.../spring+steel/
29th May 2020, 05:31 PM #4Most Valued Member
I got no idea if this helps or if it's the type of spring steel you are after but on eBay there are numerous sellers selling 0.5mm piano wire in 1 m lengths for reasonable prices.
30th May 2020, 05:07 PM #5
Thanks for the suggestions so far, everyone.
Cheers Matt
30th May 2020, 05:36 PM #6Senior Member
- Aug 2013
- 229
Spring steel
Not sure about 1095, but is this any good?
Peter
30th May 2020, 06:02 PM #7
31st May 2020, 02:11 PM #8Most Valued Member
Just re-read your post. Your not going to want piano wire like I suggested. Lol.
Big help I was!
31st May 2020, 06:21 PM #9
31st May 2020, 07:01 PM #10Most Valued Member
- Healesville
- 2,129
31st May 2020, 07:35 PM #11Most Valued Member
31st May 2020, 07:36 PM #12
S,H
If it’s 1095 (Which I think most commercial bandsaw blades are)
I would be happy like a pig in mud,
Tho the sizes I would need ,are minimum would be say 60/70 mm wide by say 200 mm long.
Such as a small dovetail saw(small )
But it would be great if I could get big sizes too.
So that would be a pretty big bandsaw blade.
Cheers Matt
31st May 2020, 07:37 PM #13
31st May 2020, 07:44 PM #14Most Valued Member
Matt, I've seen 200mm wide bandsaw blades in the back of the delivery truck, so 70mm shouldn't be a problem.
31st May 2020, 07:50 PM #15
Thanks Kryn,
I think it’s definitely worth looking into.
Actually it’s definitely definitely worth looking into.
There’s a place in Melbourne that sell Oregon ,
They have a monster bandsaw is the factory for re sawing logs.
An I’ve seen the blades sitting on the side,there very big.
Cheers Matt.
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
By fudo133 in forum METALWORK GENERALReplies: 3Last Post: 25th Jun 2014, 12:44 PM -
Annealed Spring Steel
By Dick Turpin in forum METALWORK GENERALReplies: 16Last Post: 5th Oct 2011, 12:19 PM -
looking for some spring steel
By benupton in forum METALWORK GENERALReplies: 2Last Post: 5th Feb 2011, 09:05 PM -
Spring Steel
By Big Shed in forum METALWORK GENERALReplies: 4Last Post: 8th Jul 2009, 09:01 PM -
Spring Steel
By MICKYG in forum METALWORK GENERALReplies: 9Last Post: 27th Sep 2005, 10:41 PM
