Results 1 to 6 of 6
27th May 2020, 06:13 PM #1Senior Member
- Mar 2017
- Brisbane
- 245
Cheap oil skimmer I can buy for a cnc?
Hare and forbes have a $500 model, I just can't bare to spend that at the moment! I'd rather spend it on tooling!
I also, however, am extremely lazy... There are many good models over in the USA, but our exchange rate is terrible as we all know. Anyone have any great ideas or sources for a cnc coolant oil skimmer?
I should add I use the cnc once every week to fnite at the moment, busy with my main job, and it sits dormant at a friends shop in the meantime. I want to be able to come over and stop it from going rancid once a week, so i wont be using it very often.
Edit - just found this - https://youtu.be/yuvvgqj8b3E?t=723 - makes an oil skimmer out of a plastic bucket and an aquarium pump. Looks great.
27th May 2020, 06:45 PM #2
Hi J3D,
Remember oil floats on top of water/coolant ! So any tank that has a weir across the top extending a couple of inches or more below the water surface will trap oil on one side and the clean water/coolant will end up on the other side.
How you remove the oil on the surface is up to you. Blotting paper works as does skimming it off. But you must keep the water/coolant level above the bottom of the weir or you will end up with oil on both sides.Best Regards:
27th May 2020, 07:58 PM #3Senior Member
- Jan 2012
- 149
We made one using a 400mm disc of 6mm polypropylene and a geared motor, fairly easy as our coolant tank had a separator built in.
Also have a Skimpy belt which works ok, probably a little expensive now.
https://www.skimpyoilskimmers.com/
28th May 2020, 08:34 PM #4Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
We have a vertex one at work, think it was about $300, but that was a few years ago. Skimmers seem to be expensive for such a simple thing. shop around to, H&F isn't the only tooling supplier in the country and they aren't always the cheapest. the other thing to look at is a coolant coalescer, might be easier to DIY. What do you think of your mill?
28th May 2020, 08:35 PM #5Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
28th May 2020, 10:19 PM #6Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
I fitted one of the Disc type with diverter, from Dimac, to a CNC lathe at work, it does remove some of the tramp oil but not all of it, I will try the belt type next time.
cheap VFD
By dodge at4 in forum ELECTRICALSReplies: 9Last Post: 3rd Dec 2017, 10:15 PM -
Cheap saw 6*4
By azzrock in forum METALWORK GENERALReplies: 32Last Post: 13th Apr 2017, 10:30 PM -
Cheap Protection from Super Cheap.
By Anorak Bob in forum METALWORK GENERALReplies: 4Last Post: 30th Apr 2014, 12:01 AM -
...that went cheap
By eskimo in forum METALWORK GENERALReplies: 9Last Post: 6th Jun 2011, 11:11 PM -
Cheap vices at Super Cheap Auto
By LordBug in forum METALWORK GENERALReplies: 19Last Post: 5th Jun 2011, 01:14 AM
