Results 1 to 10 of 10
Thread: Home made hand planer
19th May 2020, 07:23 PM #1Gear expert in training
- 34
- 1,080
This is genius https://www.youtube.com/watch?v=N1XwgdnA93I
19th May 2020, 08:19 PM #2Most Valued Member
Thanks for that Elan, a looks bit toooo much work for me.
19th May 2020, 08:56 PM #3Most Valued Member
I don't understand, what is he trying to do?
19th May 2020, 08:59 PM #4Gear expert in training
- 34
- 1,080
It's in the video description, but basically he wanted to true up the dovetails without having a dovetail straightedge.
19th May 2020, 09:50 PM #5Most Valued Member
It's like planing a piece of wood, TRYING to get it flat, I just make it worse.
Taking off a couple of thou at a time, seems like a lot of work.
20th May 2020, 12:24 AM #6Golden Member
- Dec 2011
- 505
Rivett 608 1.jpg Rivett 608 (Image from lathes.co.uk)
Takes me back.
My first lathe was a Rivett 608, or at least the cannabalised and worn out remains of one. All the complex bits were missing, so no power feeds or screwcutting. The ways were very worn, but unlike the guy who made the video I had the bed ground - in those days it was quite affordable.
It is not apparent from the video, but the carriage runs on flat surfaces - front, top and back of the bed - plus the two angled surfaces of the dovetail way (behind the carriage apron when the lathe is assembled). So if you have scraped the flats on the front, top and back true these can be used to guide the sled for planing the angled surfaces of the dovetail. Interestingly it did not look that hard a manual task, maybe because the tool is only taking off a controllable smidge per stroke.
Bill
20th May 2020, 12:58 AM #7Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
20th May 2020, 07:46 AM #8Most Valued Member
I'm suspect on his method. I doubt it's going to achieve a satisfactory result.
For starters, the bed I just sitting on a timber bench. Even if you are able to plane the bed flat, if its got twist in I t then you will end up planing a twisted bed flat. Then when you go to level it before use, it will be a pretzel.
20th May 2020, 11:11 AM #9Golden Member
- Dec 2007
- 574
Back in the late 1960's my school mate's uncle did the same thing, he was given a well used ancient lathe from a high school and trued up the worn bed much the same way. A few months later he proudly showed me his PO8 target pistol with a new barrel fitted, he had turned the barrel up from a 9mm blank.
20th May 2020, 11:28 AM #10Golden Member
- Dec 2011
- 505
If you check the description of the video he says he has scraped and trued the surfaces that guide the planing sled.
While it's not well supported just lying on the timber bench, the Rivett bed aint a lightweight casting - it's solid apart from two narrow chip evac slots down the middle, so very rigid compared with your typical small lathe bed. There will be some twist and bend due to the quality of support, but the sled should follow these imperfections and reproduce the dovetail inner faces quite well in relation to the surfaces that have been trued.
Clearly he is not going to achieve the original precision of the machine ("guaranteed to turn, face and bore straight to within 0.001" in any six inch length"), but still looks to be a serviceable repair for home use.
Bill
Home made U bolts Vs buying ready made
By gazza2009au in forum TRAILERS & OTHER FABRICATED STUFFReplies: 13Last Post: 14th Aug 2019, 05:17 AM -
Hand made scrapers
By Michael G in forum METALWORK GENERALReplies: 7Last Post: 7th Mar 2012, 09:57 PM -
Hand Made Hardware
By LR09WA in forum METALWORK GENERALReplies: 12Last Post: 9th Jun 2011, 03:19 PM -
Starrett planer & shaper gauge n0 246 scotland made
By Stustoys in forum METALWORK GENERALReplies: 43Last Post: 21st Apr 2011, 09:27 AM -
Hand made s/s cabinet fitings
By Andy Mac in forum METALWORK GENERALReplies: 8Last Post: 5th Jun 2007, 08:55 AM
