Results 16 to 30 of 31
  1. #16
    6,475
    Since it has an anti rotation key, I reckon that it goes on the end of a shaft and between it and the sidewall of the box !
    Could be that when it was originally fitted, it wasn't properly in place and not located on the lug for the key. So when the shaft was put in, the thrust washer was trapped at an angle, squashed and then broke and dropped into the bottom of the box.
  2. #17
    Apr 2020
    Ettalong Beach NSW
    62
    72
    I spent ages trying to work out shere it came from, to no avail. I couldn't find any shaft with the same diameter. The only thing I could come up with was that perhaps it came from the lower shaft that connects to the forward/neutral/reverse switch. As the picture shows, the switch extends beyond the dimple, and testing it by hand, it locks up the whole mechanism. So perhaps it was to prevent the switch from extending too far?
    Given that the previous owner was running it without issue, I'm contemplating doing the same.Attachment 386769
  3. #18
    6,475
    Hi Vic, Guys,
    If you can see into the box where that lever is, you might be able to see a recess where that thrust washer belongs. It might be there to ensure that some gear or other lines up properly and not riding on the teeth edges.
    I doubt that the manufacturer would have put a thrust washer in if it hadn't been necessary.
  4. #19
    Apr 2020
    Ettalong Beach NSW
    62
    72
    Yes, I agree with you. I can see right down into the lower section, as per pic. However, I cannot find any shaft that looks like it would fit this size/shape.
  5. #20
    Apr 2012
    Healesville
    2,129
    It's an "over the shoulder part"
  6. #21
    May 2011
    Murray Bridge S Aust.
    5,959
    Would it be possible that it (used to) fit between a couple of gears??
  7. #22
    Apr 2020
    Ettalong Beach NSW
    62
    72
    I'll have another look tomorrow. If I only had a parts diagram of this model...
  8. #23
    6,475
    Hi John,
    I thought that was supposed to be salt
  9. #24
    Dec 2010
    Syd
    492
    Does the witness mark look like it will match any other diameter?
    At first impression, would appear to me to be as Baron J states, something next to a casing. Hard to tell ID with no scale, any rotating levers outside the headstock removed in the process? Reminds me of some old iron vices that had split thrust rings like that for rotation of the handle.....even if this one is not designed that way and broken.
  10. #25
    Apr 2020
    Ettalong Beach NSW
    62
    72
    To my untrained eye, I cant see anything that matches. I've spent ages looking, and moving every associated lever.
    Nothing was removed in the moving process.
    Thanks for trying to help figure this out.
    I ran it briefly yesterday and moved levers (whilst stopped), and gained no insight.
  11. #26
    Jul 2006
    Athelstone, SA 5076
    4,258
    as the Aprentice says above the break is not at 180 degrees.
    It has an anti rotation notch???, which may suggest its id is reasonably close to shaft size?
    therefore, how did the larger piece fall of or out?
  12. #27
    Nov 2010
    Frankston south
    102
    Don't know if this will help but some pictures of mine...IMG_0679.JPGIMG_0680.JPGIMG_0681.JPGIMG_0682.JPGIMG_0683.JPGIMG_0684.JPG
  13. #28
    May 2011
    5,959
    Thanks for that, doesn't look like there's any type of thrust washer in any of your pics.
  14. #29
    Nov 2010
    Frankston south
    102
    I am of the same opinion
  15. #30
    Apr 2020
    Ettalong Beach NSW
    62
    72
    Thanks for your effort. Looks like mine.. I can't see anything that resembles the washer. Most puzzling.
  1. Lathe gearbox ,slide oil
    By Woodyo in forum METALWORK GENERAL
    Last Post: 15th Feb 2018, 04:59 AM
  2. Found an old Hembrug lathe, how fixable is she?
    By sillywilly in forum METALWORK PROJECTS
    Last Post: 1st Sep 2017, 10:01 PM
  3. Oil for Lathe Gearbox/Apron
    By markjaffa in forum METALWORK GENERAL
    Last Post: 12th Mar 2010, 04:33 PM
  4. Saw a lathe on Ebay today
    By Sterob in forum METALWORK GENERAL
    Last Post: 7th Feb 2007, 11:00 PM
