Results 1 to 3 of 3
16th May 2020, 11:04 PM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
How to fix broken retractable air hose reel
Factory neighbour asked me to try to fix their retractable reel - you know the ones that I can never work out how to lock after you have pulled some hose out?
After taking the fixed swivel hose centre off and removing the cover, it became obvious the clock spring end had broken – where the 90° bend is:
Spring is 25mm x 1.6mm section. I was about to measure the length and look on eBay for a new spring, until I looked at the other end, where they have a pin through two holes to form a loop.
Aha! I can bodge up a clamped solution. First, clamp the spring in place, then grind a hole:
using a Dremel™-like tool (spring seemed too hard to drill), then find a saddle clamp:
and bend it, so a bolt can hold the spring in that slot:
Reassemble, and it works well enough.
The saddle clamp is flimsy (mild steel, probably thinner than the spring steel), but it is only locating the spring in a slot. Should give the owner another decade?
16th May 2020, 11:25 PM #2Most Valued Member
Nice fix. That's the trouble with springs like that, the ends break off and makes them useless, till NOW, THANKS.
17th May 2020, 07:34 AM #3Most Valued Member
Nice job.
Great to build up credit with your neighbours. Never know when you may need a favour!!
Overhead retractable power cable
By node105 in forum METALWORK PROJECTSReplies: 13Last Post: 10th May 2020, 08:34 PM -
A Simple Retractable Threading Tool
By Anorak Bob in forum METALWORK GENERALReplies: 24Last Post: 3rd May 2018, 11:15 AM -
How to modify fishing reel
By Arron in forum METALWORK GENERALReplies: 23Last Post: 21st Aug 2015, 09:51 PM
