Results 1 to 8 of 8
Thread: Dufour 624C Overarm Support
16th May 2020, 09:21 AM #1Golden Member
- Apr 2019
- 596
Does anybody have or know of a Dufour 624C overarm support that I may be able to purchase? Failing that, would anybody have any idea of where I might find some plans for one so that I can make it? My last resort is to measure the mill and come up with my own design.
EDIT: I am not after the long shaft but the head that mounts on the 2 shafts and supports the arbour.Last edited by Mk1_Oz; 16th May 2020 at 09:29 AM. Reason: Clarity
16th May 2020, 12:40 PM #2Most Valued Member
- 4,890
You might be lucky but I would say if it's only for standard rather than heavy duty horizontal milling you would be better of fabricating your own.
16th May 2020, 01:14 PM #3Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Mill overarm support
Hello from BC.
If you search on Youtube for This old Tony, Mike Walton, Jimmy John. All three have videos of of making a support. Also I'm sure Abom79 made a bush and oil resivour for his.
BC
16th May 2020, 07:22 PM #4Golden Member
- Apr 2019
- 596
I don't think making one will be too hard. If I can get the overhead arm holes right then I can use the horizontal spindle to spot a hole for the bearing. Cast iron or steel? Would it make any difference?
16th May 2020, 09:28 PM #5Most Valued Member
- 2,666
I don’t think it will make much difference, so I’d make it out of whichever is easier to source.
16th May 2020, 10:33 PM #6Most Valued Member
- 4,890
You would probably need a piece of cast around 200 diameter maybe a touch more.
Fabricated out of mild round and flat with a bronze bearing would probably be cheaper.
16th May 2020, 11:09 PM #7Senior Member
- Mar 2009
- Blue Mountains
- 195
The original was probably a cored out iron casting. replacing it with an iron or steel machined solid part will make it a fair bit heavier and awkward to fit and remove. Using solid aluminium might be an alternative which would be much easier to get and make the machining much easier as well. Although my mill is smaller than yours the Support is an aluminium sand casting with a bronze arbour bush so there is a precedent.
Mm.
17th May 2020, 09:05 PM #8Golden Member
- Apr 2019
- 596
Thans for the input all. Ally would be easier to mill also. Not sure cost wise..
Is there a PDA support group?
By DSEL74 in forum ANTIQUE AND VINTAGE MACHINERYReplies: 24Last Post: 4th Mar 2017, 03:59 PM -
One for Greg Q - Check out the overarm.
By Anorak Bob in forum METALWORK GENERALReplies: 1Last Post: 22nd Apr 2011, 06:52 PM -
Overarm jammed on horizontal mill
By 19brendan81 in forum METALWORK GENERALReplies: 19Last Post: 1st Sep 2010, 01:09 PM
