Results 1 to 15 of 17
10th May 2020, 06:29 PM #1Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
A Better Manifold for Home Compressor
My WTD 12 CFM Compressor felll over in the trailer the other day and damaged the outlet on the Manifiold.
I Googled and could only find the same cheap and cheerful version on Ebay.
I bought one and I have damaged that as well, due to not realising how soft the cast metal is....grrr
Anyone know of a good source for 'proper' compressor parts?
10th May 2020, 07:20 PM #2Most Valued Member
You'd probably be better off getting a few T pieces and nipples/sockets etc, in 1/4" Brass, and make up a set yourself, as all I've ever seen is the same as you've pictured. Or get a block of brass bar and make a manifold, utilising some of your existing fittings.
If you've a truck dismantler nearby, look in there as some run 1/4" fittings
10th May 2020, 07:34 PM #3Diamond Member
- Aug 2006
- 1,106
Different compressor but similar manifold. I had a small leak and decided to tighten the fitting and the die cast manifold decided to break apart.
So made something up out of bits I had laying around.
10th May 2020, 08:00 PM #4Member: Blue and white apron brigade
I agree. If you want to go a little bit classier, try the SS fittings from of all places Blackwoods as they are really well priced. I've used them for quite a few of my comp air projects. As I was interested in improved flow and lower pressure drops out of my compressor, instead of 1/4", I used 3/8 or even 1/2" including hose and the 1/2" Hicupla Nitto fittings. For taps/valves I use the 1/2" plumbing ball taps from bunnings.
10th May 2020, 08:18 PM #5Member: Blue and white apron brigade
Heres a few of my manifolds
Shop made very low pressure piston and manifold for calibrating dust collector pressure sensors
Testing the new coffee machine pump.
Setup.JPG'
10th May 2020, 08:58 PM #6Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
What about utiilising something like this https://www.ebay.com.au/itm/1-4-G-5-...bvUVcgw1Ip1Bgw and mounting your parts onto them. I think the material might be anodised aluminium.
All The Best steran50 Stewart
10th May 2020, 09:46 PM #7Senior Member
- Jul 2007
- 332
Steve, Nescco used to carry a wide range of air fittings, not sure if they are in your area, if not they have an outlet on Welshpool Rd, Welshpool. Alan.
10th May 2020, 11:22 PM #8Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Thanks Guys,
Some good ideas there.
Not sure what I'll do yet.
Didn't think of those Ali manifolds....That might work out well.
Don't really want to have millions of fittings. ( As an Instrument Fitter, its a natural instinct NOT do that...lol)
Have not heard of Nescco so assume they ar eonly in Perth. I'min Bunbury.
We have Blackwoods so might look at their catalogue.
10th May 2020, 11:44 PM #9Senior Member
- Perth, Western Australia
- 67
- 362
I don`t mount anything on the compressor other than a ball valve. I have seen to many brake because of having a whole heap of fittings hanging off them.
I run flexible line to a collector then more flexible line to manifolds mounted around the garage. Push fit stuff is the only way to go.
Tony
11th May 2020, 12:32 AM #10Member: Blue and white apron brigade
11th May 2020, 01:49 PM #11Senior Member
- 67
- 362
28th Dec 2022, 05:53 PM #12Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Well, I have just broken another manifold.
This time I was swapping the pressure relief and blanking bungs over so I had better access to the PR..more fool me. I should have know to leave well enough alone....doh.
I have cracked the cast cheese metal where the PR should screw in......Its completely stuffed...no way to repair it.
Back to square one.
28th Dec 2022, 08:11 PM #13Most Valued Member
Use larger brass fittings and mount them on the end of a hose and fitted to the shed.
Yes, it'll cost a bit more, but how many cheesy ones do you want to go through???? Buy once and buy right.
I've stripped a few Swiss cheese ally ones just trying to fix a minor air leak.
28th Dec 2022, 08:53 PM #14Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Thanks Kryn. I don't want to go through any more!
I can't find any other comercial options so I think I will make my own. I don't really want to hang one on the wall. I move my compressor around when using it.
Looking into buying some aluminium square stock ( probalby around 40 x 40mm ) and mount everything onto that.
Something like this.
29th Dec 2022, 05:34 AM #15Most Valued Member
- 2,673
Total tools have these manifolds.
Not as cheap as making your own (assuming you already had suitable tap etc) but easier..
https://www.totaltools.com.au/66831-...p-male-120m045
Refrig manifold and gauges
By eskimo in forum METALWORK - Machinery, Equipment, MARKETReplies: 9Last Post: 2nd Jun 2020, 11:12 PM -
Rebuilt rusted out gas manifold on my grill with 304L stainless steel
By Weekend.Warrior in forum METALWORK GENERALReplies: 0Last Post: 8th Jul 2019, 10:09 AM -
Hole MIG welded up in tractor exhaust manifold.
By aametalmaster in forum METALWORK GENERALReplies: 1Last Post: 3rd Apr 2013, 05:53 PM -
MIG welding a cast iron exhaust manifold.
By aametalmaster in forum WELDINGReplies: 4Last Post: 19th Feb 2012, 11:50 PM -
Turbo Manifold Build
By Spencer* in forum METALWORK GENERALReplies: 16Last Post: 17th Aug 2011, 03:21 PM
