Results 1 to 7 of 7
Thread: Home made boring bar
8th May 2020, 05:34 PM #1China
- Dec 2005
- South Australia
- 1,656
I have been trying to purchase a HSS Boring Bar for my small Lathe, tool holder takes 10mm/3/8 tools can't seem to find anything, I have decided to make one is 4140 ( I have plots of it) suitable for the bar with a HSS cutter
brazed on.
8th May 2020, 08:57 PM #2Most Valued Member
- Jun 2012
- SA
- 1,649
Yes. Should be fine.
The worst that can happen is you will fail.
But at least you tried.
8th May 2020, 09:36 PM #3
Hi China,
I've made a few boring bars in my time !
Personally I would prefer not to braze anything. I use bits of broken taps, drills, in fact anything that I can usefully grind to make a cutter that I can fit into a hole in any old length of suitable (read right size) rod or bar, even turning a bit of square down to fit.
Here are some pictures of ones that I've made. That first one is a piece of HSS tool bit, that I ground down. Originally for internal threading. Then I bought an insert tool which I now use for threading. And that is only because of the difficulty of grinding single pointing threading bits. A carbide insert for threading is wonderfulBest Regards:
8th May 2020, 09:59 PM #4
A grade 8 bolt is a good cheap source for the 4140 to make the bar. The ones I have used drilled and tapped very nicely.
The 16mm fits into one of my QCTP post units. From there I can step them down to the diameter i need.
Like Baron J I save all my broken HSS pieces.
It works well and is cost effective.
9th May 2020, 12:50 AM #5China
- Dec 2005
- South Australia
- 1,656
Thanks for the suggestions I will rummage through my "I will need that one day pile" and see what I come up with.
10th May 2020, 12:02 AM #6Most Valued Member
- Healesville
- 2,129
China i dont know what your lathe can handle but you can also weld a 10mm thick bit of flat on the side of a larger dia bar, or even a few diameters and lengths to give you a bit of range in the size/depth of holes
10th May 2020, 09:46 AM #7Member
- Oct 2017
- Lismore, NSW
- 58
G'Day China,
Here is a Ø8 boring bar made from a M8 grade 8 bolt shank. The HSS tool bit was ground from a broken No.1 centre drill, that sits in a drilled hole. The HSS is held in position by an M3 grub screw in the end of the bar. This was used to cut a 2.5mm wide keyway, but could also be used for general boring.
Hope this helps.
Regards,
Don.
Home made U bolts Vs buying ready made
By gazza2009au in forum TRAILERS & OTHER FABRICATED STUFFReplies: 13Last Post: 14th Aug 2019, 05:17 AM -
Home Made Lathe
By gazza2009au in forum METALWORK GENERALReplies: 104Last Post: 2nd Oct 2017, 10:04 PM -
Home made spacers
By morrisman in forum METALWORK GENERALReplies: 1Last Post: 4th Oct 2015, 11:07 PM -
Home made Boring Bar. Advice needed.
By ventureoverland in forum METALWORK GENERALReplies: 10Last Post: 26th Jun 2014, 08:42 AM -
Home made mailbox
By Ozziespur in forum METALWORK GENERALReplies: 17Last Post: 4th Jul 2011, 11:57 AM
