Results 1 to 6 of 6
Thread: Ball castor stem replacement
7th May 2020, 01:54 PM #1Senior Member
- Apr 2018
- 168
I picked up a old drinks trolley. It was missing 2 of the 3 ball castors. The stem on them is 5mm which i cant seem to find replacements.
I found in shed similar ones but stem is too thick.
Does anyone know how to remove the stem so I can machine down the stem to size. Or where I could source new ones from.
Trolley
Original
Possible replacement
7th May 2020, 02:40 PM #2Senior Member
- Sep 2009
- Newcastle
- 341
What equipment do you have?
Lathe? Mill?
If not removable, you could potentially use a boring head with the tool facing inwards. Would require some careful work holding and alignment but doable if you can't remove the stem.
A photo of the underside where the stem inserts would be helpful.
7th May 2020, 03:11 PM #3Senior Member
- Apr 2018
- 168
Yeh No lathe or mill. Lost those toys when I retired.
Cut up the spare one and found the stems are only push fit with a small c-clipin a groove holding them in place.
Might be able to thin them down by holding and spinning in a drill while up against my linisher belt.
They arent seen so not to critical on the finish.
7th May 2020, 03:41 PM #4Senior Member
- Apr 2018
- 168
Done. 5 min on linisher then put stem into pedestal drill chuck and finished off with file.
8th May 2020, 12:01 AM #5Most Valued Member
- 5,945
Who needs a lathe when you have a Drill Press!!!!!
Have done that quite a few times at work, to make a special sized pin.
8th May 2020, 02:25 PM #6Senior Member
- Apr 2018
- 168
Thanks Kryn and Pippin88
Fixed for now. Ill try and find some more like the originals but till then it looks the part.
I found it on verge pickup. Its a Luigi Massoni designed drinks trolley made by Guzzini in 1970's .
So much for the up and over ball turner.
By Anorak Bob in forum METALWORK GENERALReplies: 6Last Post: 19th Nov 2011, 11:23 AM -
Ball weight
By Stustoys in forum TRAILERS & OTHER FABRICATED STUFFReplies: 8Last Post: 30th Jan 2011, 08:07 PM -
Replacement ball valve oilers/oil hole covers
By markjaffa in forum METALWORK GENERALReplies: 11Last Post: 2nd Nov 2009, 12:31 AM -
first try at a ball
By turbo TA in forum METALWORK GENERALReplies: 10Last Post: 25th Aug 2009, 11:32 AM -
Having a ball
By Buncha in forum THE HERCUS AREAReplies: 0Last Post: 24th Mar 2009, 08:55 PM
