Results 1 to 15 of 20
6th May 2020, 06:41 PM #1New Member
- May 2020
- Edinburgh
- 41
- 8
Can anyone help me understand how this was done?...
I'm here in hope rather than expectation. We work with furniture and have found these flattened/canted springs inside a footstool. The footstool and associated sofas were produced in (West) Germany sometime in the early 80s. We need to recreate these for another project.
These flattened springs have started life as regular extension coil springs and then been flattened/rolled using an as of yet unknown piece of machinery or process. I've been in contact with around 20 different coil spring manufacturers around the world, none of whom can tell me how these were produced - so it's likely a two-step process has been used to turn regular coil springs in to these.
The spring wire diameter is approximately 2.0mm, and the outer diameter of the original coil looks be around 15mm. We believe they are made of stainless steel - but is there a way to confirm this - some sort of analysis that could be carried out to find the exact composition of the metal?
Does anyone have any idea which sort of machine or process could have produced these into this shape?
6th May 2020, 08:33 PM #2
Welcome to the MetalWork forums,
You will find a bunch of knowledgeable,experienced and helpful fellows here on the forum.
Feel free to explore our sub forums for all of what we have to offer. Go to the FORUM box in the LH corner,the one with the little white down arrow and click.
Click again on Forum Home and it will take down the page where all our sub forums and other helpful links are.
Again welcome to the Forum
6th May 2020, 08:55 PM #3Gear expert in training
- 34
- 1,079
Simple, take a regular coil spring and squash it with some sideways movement along its length. As a proof of concept, I carefully took a hammer to the spring from a clicky pen and I'd call that pretty much the same.
For mass production, I imagine that as a continuous spring comes off the coiling machine it might be guided through a pair of rollers to flatten it and then either wound onto a drum or cut to set lengths.
6th May 2020, 09:47 PM #4Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Some stainless steels are non-magnetic.
Some grades of stainless steel can be made into springs.
It may be that your samples are normal spring steel that has been electroplated - zinc, nickel?
6th May 2020, 10:50 PM #5New Member
- May 2020
- Edinburgh
- 41
- 8
Thanks for this - very helpful.
The profile height of the post-flattened springs are around 5.0mm, so with that in mind, what sort of rollers might produce this?
When I had a look quick online, I could only find rolling machines that allow sheets/metal up to around 2.0mm/3.0mm thickness - is this standard or would there be a machine that could roll them at around 5.0mm thick?
6th May 2020, 10:53 PM #6New Member
- May 2020
- Edinburgh
- 41
- 8
6th May 2020, 10:53 PM #7Gear expert in training
- 34
- 1,079
Thickness is not an issue, there are machines that will roll 50mm, they're just bigger.
If you really need to know exactly what it is, look for material analysis companies near you, they will be able to test a sample of it and confirm but that seems like overkill. Why does the material have to match? Could you not just use whatever springs are made of today?
6th May 2020, 11:03 PM #8New Member
- May 2020
- Edinburgh
- 41
- 8
Thanks again - is it a 'slip roller' I'll need or am looking for? Something like this: https://www.warco.co.uk/bending-roll...lip-rolls.html ?
If so, I can't seem to find anything online that has anything over 1.5mm capacity for mild steel (for sheet metal or otherwise).
6th May 2020, 11:09 PM #9Most Valued Member
- Healesville
- 2,129
It will be made with spring wire, if you google your local spring manufacturers you should be able
to find one to make them for you.
As elan has said they are just a squashed coil.
The annealed wire would be formed into the coil and then flattened, most likely pressed between two plates, then they would be heat treated.
https://www.google.com.au/search?ei=...sclient=psy-ab
6th May 2020, 11:16 PM #10China
- Dec 2005
- South Australia
- 1,657
As said a rolling mill would do job the may have been hardened after flattening, how many do you need to produce, for a one off job a simple set of rollers could be fabricated
6th May 2020, 11:23 PM #11New Member
- May 2020
- Edinburgh
- 41
- 8
Apologies for my ignorance, but would you use a 'slip roller' like in the first attached picture, or a 'rolling mill' (second attached picture) for this sort of job?
Could it be heat treated prior to going through something like this, which would perhaps help the rolling/flattening process?
6th May 2020, 11:30 PM #12New Member
- May 2020
- Edinburgh
- 41
- 8
6th May 2020, 11:31 PM #13Most Valued Member
- Healesville
- 2,129
no way will a roller flatten springs,
6th May 2020, 11:41 PM #14Gear expert in training
- 34
- 1,079
6th May 2020, 11:48 PM #15Most Valued Member
- Healesville
- 2,129
How To Understand Engineers..........
By KBs PensNmore in forum GENERAL DISCUSSION / OFF TOPICReplies: 2Last Post: 8th Jan 2020, 09:59 PM -
IMPORTANT Can,t understand the Auction thingy whatsit
By Heuy in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 5Last Post: 22nd Oct 2014, 03:46 PM
