Results 16 to 30 of 31
3rd May 2020, 11:07 AM #16Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
Use the Ericsson channel. Make some flat bar sections that sandwich the channel flanges possibly.
3rd May 2020, 08:14 PM #17Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
Nigel / RT,
Telstra also, 43 yrs, 47 weeks, started in Jan 1975 at North Strathfield. Assigned to Telegraph Install in 76 installing telex machines till August 88. Went to Data cabling installing RASS, Dcris & TRAC etc, in sales offices & exchanges for 2 years. From there it was Data Install, installing NTU's & modems. Feb 97 stated installing Cisco gear customers & first maintenance for BigPond as well. Also installed Mega-links & ISDN 10/20/30. Last 3-4 yrs was a major comms network Australia wide. Last 18 yrs at Regents Park here in Sydney. Redundancy finally Dec 2018.
John Q
3rd May 2020, 09:15 PM #18Senior Member
- Nov 2011
- 123
Nigel, did you know Frank Nische.
3rd May 2020, 09:16 PM #19Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
3rd May 2020, 09:30 PM #20Senior Member
- Nov 2011
- 123
He was one of Data's to engineers and member of the CCITT.
4th May 2020, 08:40 AM #21Novice
- Apr 2020
- Germany
- 12
6th May 2020, 07:53 PM #22Diamond Member
- Aug 2019
- 1,195
RacingTadpole and JohnQ, here's a challenge for you. What are these for:
I thought they were clamps for this trayway, but the M8 set screws only just clear the depth of the clamp.
The captive nut slides, so something strangely adjustable.
P.S. Tried to buy some beam clamps. These cast ones:
Screen Shot 2020-05-06 at 6.35.15 pm.jpg are reasonable – between $8 and $12.
The one-piece ones for channel strut, however:
Screen Shot 2020-05-06 at 6.35.02 pm.jpgare crazy – $37 plus GST each.
Looks like I will be fabricating
6th May 2020, 09:23 PM #23Most Valued Member
- Mar 2011
- 1,554
The clamps are for tel-tray. Later exchange builds (mostly H2/H3 heat management) had tel-tray platforms you could walk on above the racks. Tel-tray is 150mm wide cable tray with the cable tie bumps pressed into in the inverse of the orange stuff you have, ie instead of the bumps are pushed up out the back of it. It’s mounted flanges down and the clips you have fit over the inside edge of the flange and the bolt goes through the slotted unistrut into the captive nut to secure the tray and stop it skating off the unistrut.
Ive literally rattled up thousands of them.
6th May 2020, 09:34 PM #24Most Valued Member
- Mar 2011
- 1,554
Looking back at your first post and the picture of the Macgyver hardware, do you have a supply of those grey clamps that are holding the DDF hardware onto the beam?
7th May 2020, 09:29 AM #25Diamond Member
- Aug 2019
- 1,195
Yep, 14 pairs:IMG_0042.jpg
I think they are floor grid/mesh clamps. My MacGyver solution was to grind a locating slot in the long one, drill 2 holes in the strap, and bolt up:
My worry was just the bend in the strap from the middle hole (closest to the cantilevered tray):
I think the tension required to clamp securely was too high. Many things would help;
- Grind the slot deeper, so the clamp was flatter on the beam flange.
- Thick washers between strap and clamp.
- Use two MDF straps. Line up the dimples, and viola
4th Jun 2020, 09:23 PM #26Diamond Member
- Aug 2019
- 1,195
What I ended up using to caltilever tray off an i-beam
So, to wrap up, I did end up using the flat bar, and several other leftovers. Here is the "design":
The flat bar is actually 25x6mm and fairly soft steel. Its nowhere near as tough as angle iron or strut would be, so I decided to use as many as I had the clamps for – 15 over an 8m span – basically over-engineering it.
So, start with the bar. Notice there are two small holes on one end. They originally had little bits of angle iron bolted onto them. I shortened the angle iron, and attached on the outside edge (to use as a locating stop for the trayway):
Then attach the spring clamp, which loosely holds the back of the bar onto the i-beam, and grind/file a step to fit the flat bar:
A few more bolts and nuts, and viola:
...still working on the rest of the span, as I am cleaning thick dust as I go:
6th Jun 2020, 07:43 PM #27Diamond Member
- Aug 2019
- 1,195
... and he's climbing the ... trayway to ... heaven
a drop-down channel to the middle of the floor:
IMG_20200606_153226_946.jpg IMG_20200606_161201_778.jpg IMG_20200606_161444_017.jpg
Bottom edge is a little above head height. I will bolt a bunch of power outlets, and a few air quick connect sockets, in the channel or on the back
6th Jun 2020, 08:42 PM #28Most Valued Member
- Mar 2011
- 1,554
That turned out quite good, call that a repurposing success.
20th Jul 2020, 10:15 AM #29Diamond Member
- Aug 2019
- 1,195
For the run down to my breaker box, I wanted to have a gentler than 90° bend on the cables, so...
1. Slit the tray, guess 45° and cut a cardboard template:
2. Fab' a bracket from an old wheel clamp back plate:
3. The horizontal tray is offset a bit from the vertical run, so one side gets flattened, and an odd bracket:
4. Installed:
P.S. Shortening some live conduit with a huge, rusty, old plumbing pipe cutter:
20th Jul 2020, 06:45 PM #30Senior Member
- Nov 2011
- 123
Nigel
Nothing wrong with CAD, Cardboard Added Design. Works well.
JohnQ
Where can I find out how to attach picture??!!
By S.S. in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 3Last Post: 18th Nov 2016, 04:44 PM -
What is the correct way to attach the drawbar if welding across it is a no-no?
By MrSmith in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 16th Dec 2013, 05:55 AM -
Attach awning brackets to a Steel Hollow Section
By Z-ster in forum METALWORK GENERALReplies: 19Last Post: 6th Nov 2012, 02:23 PM -
how to attach tie down point to chassis and were to get them?
By gros21 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 5Last Post: 10th Oct 2011, 11:49 PM -
How to attach a vise to plate?
By Tiger in forum METALWORK GENERALReplies: 7Last Post: 26th Jul 2009, 09:52 PM
