Results 1 to 11 of 11
30th Apr 2020, 06:43 PM #1Golden Member
- Apr 2009
- Kingswood
- 930
Kondia FV-1 Mill Pulley Belt Size
My Kondia FV-1 has a really tight drive belt fitting.
I cannot get the belt onto the slowest speed pulleys unless I remove one of the motor mount bolts.
The photo shows in the top right corner the head of a clamp used in place of the bolt.
The manual quotes the belt as a "V" belt A 839.
Fitted is a Gates Greenstripe XL 13A0865.
My judgement is that another 10 mm separation between pulleys would be easily accommodated, making the belt a 885.
How can my situation be so different to the documented size ?
Any suggestions ?
John.
30th Apr 2020, 08:19 PM #2Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
I know in Australia our drive belts are measured on the inside, but in the USA they are measured on the outside perhaps this is causing the issue. It sounds a bit like your belt is too tight as you can't change it to the slowest speed. Is the belt tight when you change it to the other speeds ?. I tried searching for a 'A839' and a '839' Drive Belt but couldn't get anything to come up.
All The Best steran50 Stewart
30th Apr 2020, 08:34 PM #3Senior Member
- Jun 2012
- melbourne
- 341
Here's mine. I think my pulleys look the same distance apart as yours. You could probably just get a belt that fits and forget about it.
30th Apr 2020, 08:57 PM #4Senior Member
- May 2015
- Richmond
- 214
30th Apr 2020, 08:58 PM #5Most Valued Member
- 70
- 1,511
Might be way off here but is it possible you should be using an 11A belt rather than 13A?
Nev.
30th Apr 2020, 09:51 PM #6Golden Member
- Apr 2009
- Kingswood
- 930
Thanks for the inputs.
The belt is tight for the other speeds, but manageable.
Confusion on measurement:
- metric is pitch,
- imperial is inside,
- US is outside,
- AU is inside.
Sossity is probably correct, just get a bigger belt.
I will go with my gut feeling and get something like an 885.
The 11A vs 13 A needs reviewing also.
John.
30th Apr 2020, 09:57 PM #7
Some manufacturers measure inside, some outside as said above. Just order the belt the next size up if you think that will fix your problem, don't sort what's the designated size.
I went to my local bearing place last week and bought 2 x 31 inch belts, they where the metric equivalent so I took my belt along to check.
Why in this day and age there isn't a standardized size I don't know.Using Tapatalk
1st May 2020, 09:06 AM #8Most Valued Member
- Charlestown NSW
- 1,669
I have the same problem on my old Hafco. Its on the roundtuit list.
The user manual has some exploded view drawings with all the parts shown and numbered with a corresponding parts list.
On the list the belt is called "Belt". No size or anything. duh. How hard would it have been when they were setting the manual up to include the belt size?
peter
16th May 2020, 06:44 PM #9Golden Member
- Apr 2009
- Kingswood
- 930
Purchased a new belt, Gates Green Stripe XL 13A0890.
This was the nearest available to the 885 estimated.
Changed the belt today.
Complete success.
Belt noise is good, changing to the lowest pulley speed is not 'easy' but quite doable.
Some of the improvement may be in the belt section.
Old is 12.1 mm wide, new is 11.9 mm.
I am sure those that have changed a belt on a Bridgeport/Clone mill would know why I have come in from the workshop and poured a soothing ale !
Keep well,
John.
16th May 2020, 06:59 PM #10Most Valued Member
- 4,255
A section belt should be same as all clones. Mine is an A33 which is 839mm
16th May 2020, 09:33 PM #11Most Valued Member
- Charlestown NSW
- 1,669
I changed mine recently as well. Pulled the motor off to get the old belt off. Then I remembered I had some old belts and was lucky enough to find one that was slightly longer than the hold one. Also found that the bearings in the front pulley were pretty noisy. Still turn smooth but noisy. I have since bought some new ones but have yet to fit them. The lining on one of the spindle brake shoes had come off as well which was why the brake didnt work very well. I epoxied that back onto the shoe. Works great now.
Just have to make some face pin spanners so I can replace the bearings.
peter
Kondia Turret Mill - Knee Clamps
By electrosteam in forum METALWORK GENERALReplies: 11Last Post: 20th Nov 2019, 12:45 PM -
Kondia mill
By Davo81 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 3rd Jun 2019, 04:07 PM -
Pulley and Belt size speed ratio Calculator
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 4th Dec 2017, 08:50 PM -
correct vee belt size for a mill drill
By welder in forum METALWORK GENERALReplies: 5Last Post: 6th Jul 2011, 02:28 PM -
Kondia Mill Drive Belt
By electrosteam in forum METALWORK GENERALReplies: 2Last Post: 30th Aug 2010, 09:55 AM
