Results 1 to 15 of 15
29th Apr 2020, 10:00 PM #1Novice
- Nov 2019
- Perth Australia
- 16
Moving a 350 kg Milling machine onto a base
Well I survived installing the new lathe after considerable good advice from this forum and it works - but the operator needs some more practice - and this hopefully will come with the rain !!!
I am in the final stages of buying a milling machine - and on the advice from those wiser than me - and as I have the space am looking at a mid size machine -
a Hare and Forbes HM 46 B
The problem is similar to that with the lathe in that its got to go inside a garage - ceiling height is not bad at 2.5 metres - but it weights around 350 kg
Was looking at breaking it down - but even then the bits weigh around 100kg apiece and this all has to go onto a stand
With the lathe I rented an engine hoist from Kennards and with this was able to shift the lather onto its stand ok - but dont think its big enough for this
Am looking to see it there are any gantry type cranes with a chain block that I could use - but would appreciate any advice from anyone who has been through this process themselves
Any advice on how best to lift - ie anchor points also appreciated
Rumble
29th Apr 2020, 11:57 PM #2
I've got a 2.5m ceiling as well and got my HM52 Mill in there with a 2 ton engine crane. I separated the mill head with the ram and installed it once the mill was in place.
A HM46 should be a breeze complete.Using Tapatalk
30th Apr 2020, 12:47 AM #3Senior Member
- Perth, Western Australia
- 67
- 362
My geared head drill weighs about the same and I moved that with a 2 tonne engine crane. With 2.4m ceiling height it was close. Need some short slings.
Tony
30th Apr 2020, 09:06 AM #4Most Valued Member
- Charlestown NSW
- 1,669
Kennards also hire portable gantries and chain blocks. However you would have to check to see that its not too tall for inside your garage.
peter
30th Apr 2020, 09:29 AM #5Most Valued Member
- Jul 2016
- 35
- 1,522
I would think pretty much any engine lift would be rated at 500kg minimum, even mostly extended you'll be fine.
30th Apr 2020, 04:33 PM #6Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
Drill and tap a couple of holes in the top of the column casting for eye bolts. Put a piece of solid bar through the eye bolts to lift from.
That is the least sketchy way I can think of to move an RF 45/46 with an engine crane. I used a gantry and two small chain blocks to put mine in position with 2.5m ceilings. It was a cluster... there wasn’t enough headroom, the sling angles were waaaayyy outside desirable and it was just generally a good example of not what to do (particularly given I hold a riggers ticket). I will be drilling the top of the casting when I move mine next.
Oh and make sure your crane is good for 500kg at full stick, not max when it’s short hooked.
30th Apr 2020, 06:38 PM #7
I see most engine cranes sold these days at H&F, Super cheap, Repco etc are only rated at 1250kg max close in.
You need to look harder for a heavier duty version of the 2 ton like mine with 4mm steel box section.
I think Simon has the 3 ton one, which would be nice, but a lot heavier again.
You can always take the head off, grab a piece of paper and draw where the wiring goes, also take a few pictures.Using Tapatalk
30th Apr 2020, 09:14 PM #8Senior Member
- Dec 2009
- 134
I just used an engine crane to do mine. Was a bit touch and go with the height, but lifting capacity was no issue at all.
1st May 2020, 09:31 AM #9Golden Member
- Sep 2009
- 666
I broke mine down to get it off the trailer and then rebuilt it on the stand.
1st May 2020, 09:53 AM #10Most Valued Member
- 4,887
Use the floor crane, swing head to Horizontal, sling between head and column.
1st May 2020, 03:44 PM #11Most Valued Member
- Mar 2011
- 1,536
Works but not generally considered good practice to sling off around a mobile joint.
3rd May 2020, 01:30 AM #12Novice
- Nov 2019
- Perth Australia
- 16
Moving a Mill
Thanks to all the input
Have a friend who is loaning me a full 1 tonne engine hoist - so can take my time and
Best way from another expert is to sling around the swivel head interface - with it horizonal as commented by another on the forum
Rumble
3rd May 2020, 10:41 PM #13Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 312
Engine hoists
With the talk about lifting turret mill heads and using H & F style engine hoists I'm reminded about lifting mine in to position. What I find annoying with these hoists are the angled feet. At the end they're too wide to go under the front of a car but when you need to get close to something they're too narrow. I now have the best of both worlds with a simple modification. The black bits are what I made but the photo's should tell the story better than I could explain.
My Lagun FTV-4 top section weighs well over 300kg and because of the modification assembly was a breeze.SAM_2189.jpgSAM_2190.jpgSAM_2191.jpgDSCN0348.jpg
3rd May 2020, 10:57 PM #14Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
6th May 2020, 08:08 PM #15Most Valued Member
for sale vic. laverton. Aluminium machine base.
By azzrock in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 23rd Feb 2020, 06:45 PM -
Moving a 2000kg machine
By monchochos in forum METALWORK GENERALReplies: 13Last Post: 3rd Jun 2019, 10:18 AM -
Milling Machine!
By country kid in forum WANTED TO BUYReplies: 0Last Post: 8th Jun 2016, 03:23 PM -
VICTORIA Milling Machine
By ersbruce in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 5th Jun 2012, 02:14 PM -
HM 50 milling machine
By woodfast in forum METALWORK GENERALReplies: 3Last Post: 19th Apr 2012, 07:12 PM
