Results 1 to 7 of 7
Thread: Name this welding clamp?
15th Apr 2020, 10:45 PM #1Senior Member
- Apr 2019
- Finland
- 46
- 117
Some years ago, we found a clamp that we decided to copy.
We made ten copies from it with my friend.
Its great for lining pipes & axles for welding.
It centers them automaticly, even if the diameter varies.
Do you know a name for it, or brand for the original one?
It was made from cast steel. ( One on the pictures is watercut and machined from plate)
I have been planning to make more of them.. i have only this one left.
Its not a big deal, but it would be nice to know what is it called.
15th Apr 2020, 11:12 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
I googled 'pipe alignment clamp'
Found a lot of similar ones, amongst it was this, looks identical to yours
https://www.directindustry.com/prod/...7-2229739.html
and this
https://tremcopipeline.com.au/constr...ignment-clamp/
The second link mentions them being made my Sawyer (USA)
Keep in mind by copying it you may be encroaching on a registered or patented design
Good luck with it
15th Apr 2020, 11:19 PM #3Most Valued Member
Sorry i can't help you with a name for the Clamps, but I and I'm sure others on here, wouldn't mind a set of drawings for them, PLEASE, as they look like a very handy piece of kit.
Thanks,
15th Apr 2020, 11:22 PM #4Senior Member
- Apr 2019
- Finland
- 46
- 117
Thank you very much!
I tried to Google with Finnish terms, and didn't find any.
Luckily, in Finland. One is allowed to make a copy for personal use, even that the design is patented.
You are allowed to make ones for your friends too, if you don't take money from it.
Also you are allowed to sell it, if you can show that you have used it, and doesn't need it anymore.
Here patens or model protection doesn't apply in personal use.
15th Apr 2020, 11:30 PM #5Senior Member
- Apr 2019
- Finland
- 46
- 117
16th Apr 2020, 08:08 AM #6
Looks like a Kant twist clamp, 2 of, fixtured together.
I've never used them, but the design is similar.
16th Apr 2020, 09:39 AM #7Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
I have a different type of tool that is also evidently for aligning cylinders, pipes etc. It was from technical college.
It is a single piece of cast iron, with a V shape along its top edge, flat on the bottom, and with flanges next to the V for using clamps.
Actually the V is in two sections, because there is a gap in the centre so welding can be done there.
I see you have a Rode microphone on your camera, made here in Sydney Australia.
3 axis welding clamp
By KBs PensNmore in forum WELDINGReplies: 17Last Post: 14th Feb 2020, 08:55 PM -
KANT-TWIST Round Handle Clamp 3/4", Clamp Mfg 396
By DSEL74 in forum METALWORK GENERALReplies: 7Last Post: 10th Aug 2019, 08:05 AM -
One Hand Clamp
By Anorak Bob in forum METALWORK GENERALReplies: 5Last Post: 10th Sep 2018, 06:06 PM -
Die Filer Clamp
By DSEL74 in forum METALWORK GENERALReplies: 3Last Post: 14th Sep 2015, 12:55 AM -
Wrong clamp kit?
By oohsam in forum METALWORK GENERALReplies: 6Last Post: 28th Mar 2014, 08:23 PM
