Results 16 to 30 of 30
Thread: I need a bandsaw
25th Apr 2020, 08:19 PM #16Most Valued Member
- 70
- 1,514
I ended up getting the BS-5V. Price was $660. Smaller capacity at 125mm than the BS-5S but I think I can live with that. Has variable speed and main switch is on top of motor with trigger switch on the handle unlike the BS-5S which is on the base wher it can get covered in swarf. Much lighter to handle but will still fix it to a mobile bench as soon as I can. Must have been old stock as manufacture date is 10/2018.
Fairly happy with the quality and finish of it but the real test will be cutting the heap of steel I have here for various things. Removed original blade, as I am not sure if it is still ok after being tensioned in the box for 18 months. Got a Starret blade thrown in with the purchase. Going to get three or four bi-metal blades for various things I need to cut, including RHS, some 65mm solid 4140 and 100 x 70 hollow again in 4140.
Any recommendations on what blades I need as in TPI, or just go with what the rather ordinary manual recommends?Nev.
25th Apr 2020, 09:50 PM #17Any recommendations on what blades I need as in TPI, or just go with what the rather ordinary manual recommends?
Just using M42 blades for the most part. Have a couple of M51 for the harder stuff. Ones a 5-8 TPI, the other some what finer.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
25th Apr 2020, 10:07 PM #18
Hi Nev,
I'm currently using a 12-14 vari pitch bi metal blade. The original blade that I was given, that came with the saw originally but never used, is a 3-5 vari pitch carbon steel blade. I understand intended for cutting wood. Its certainly too coarse for anything metal.Best Regards:
25th Apr 2020, 10:26 PM #19Senior Member
- Dec 2009
- 134
26th Apr 2020, 10:32 AM #20Most Valued Member
Being a tight I use one blade for everything!
I have found that a multipitch 10-14 tpi to be a good compromise for my needs. I do have to be careful if cutting wider pieces though as the swarf can clog and jam the blade.
26th Apr 2020, 11:17 AM #21Banned
- Mar 2020
- Sa
- 24
I have a BS-5s which I've put on wheels. Had it for around 5 years and generally use the 18 tip for everything except the ocassional bit of wood. Good saw.
26th Apr 2020, 01:05 PM #22Senior Member
- Perth, Western Australia
- 67
- 362
I am the same. 10-14 used to cut everything from thin to 200mm solid, Aluminium to steel. Speed is set to the second fastest and is never changed. I do use coolant and have hydraulic down feed.
Over 22 years I have used 3 blades. The last one lasted 10 years but did not get the use the early ones did.
Tony
26th Apr 2020, 06:09 PM #23Diamond Member
- Aug 2006
- 1,106
Where are you buying your multipitch 10-14 tpi blades from?
26th Apr 2020, 07:17 PM #24Senior Member
- 67
- 362
My last one was Hare & Forbes. Surprised it lasted as long as it did thought it was just home DIY stuff. The first 2 came from a small private company. They did a lot of work. Unavailable now.
Tony
27th Apr 2020, 12:09 PM #25Most Valued Member
- 2,673
I got a M42 10-14 blade made for my vertical BS by Barry at Specialty Saws ([email protected])
Only had it for about 3 months and hasn't done a huge amount of work. Happily cuts everything I've thrown at it so far - from 2mm aluminium to 25mm steel plate.
From memory it was about $30 plus post.
3rd May 2020, 09:38 PM #26Most Valued Member
- 70
- 1,514
I may mount the banbsaw to my old tool cabinet and possibly replace that with this -
https://www.totaltools.com.au/111201...blue-hrd7dttbl
Will see if they got one in stock on Tuesday. Old one has five drawers and a little less in height so may work out ok. Can then use drawers to store smaller metal offcuts and use bottom two drawers for angle grinders etc.Nev.
4th May 2020, 07:50 PM #27
Hi Nev,
Just be careful of the stability of the cabinet, with the weight your going to put on top and what weight may be in the drawers. They have a tendency to tip, relying on the weight in the bottom draws for stability.Best Regards:
4th May 2020, 08:59 PM #28Most Valued Member
- 70
- 1,514
It'll be ok. It has two fixed and two swivel castors and I consider this more stable than all swivel. We have trolleys at work which stand quite high for hanging jigs of plated stuff. The all swivel will tip over if not handled very carefully, whereas the one with a combination, is much more stable.
Nev.
6th May 2020, 10:28 AM #29Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
...while we are talking about stands, this is what I made for my scrapped 6x4...
I started with 1.8m of channel, set angle grinder cutoff for roughly 10°, halved it and angled the ends. Bolted on 2 lengths of channel on the back, and a B&D WorkMate in the front, to hold the weight while I was cleaning with a wire brush.
The square frame on the bottom was an old trolley base. Cut off the rusty castors, drilled some holes in the stainless, and bolted back legs in.
Was thinking about two legs at the front, but decided all the weight was at the back, so just used one. Of course, that means it wobbles and shakes at the front. No big deal.
After replacing and adjusting the pivot end-travel bolt, to stop blade+motor from overbalancing, stand was OK, but there is a lot of force/inertia every time the thing is swung up - the front of the base would lift up from the ground. So the Frankenstein back leg and extra bracing was cobbled together.
A very heavy base would have been better, but I can stack offcuts down there, or hang weights (which I think might be needed on the blade for some cuts!)
12th May 2020, 09:12 AM #30Diamond Member
- Sydney, NSW
- 1,249
I'm picking up this today. I really need to get my lathe and mill into the garage or I'm going to run out of space!
https://www.gumtree.com.au/s-ad/st-i...saw/1247642974
Ben.
Bandsaw
By Dave J in forum METALWORK GENERALReplies: 5Last Post: 4th May 2019, 10:04 PM -
FS BS-? Bandsaw
By caskwarrior in forum METALWORK - Machinery, Equipment, MARKETReplies: 12Last Post: 4th Dec 2018, 05:59 PM -
bandsaw
By shaper07 in forum METALWORK GENERALReplies: 7Last Post: 23rd Aug 2016, 01:34 AM -
Which Bandsaw?
By tongleh in forum METALWORK GENERALReplies: 18Last Post: 20th Nov 2012, 04:05 AM -
Bandsaw
By Pete F in forum METALWORK GENERALReplies: 25Last Post: 11th Sep 2009, 05:27 PM
