Results 1 to 4 of 4
Thread: Clarkson threaded slitting saw
13th Apr 2020, 03:06 PM #1Senior Member
- Feb 2012
- Tamworth, NSW
- 205
I’ve not been able to find if there is such as thing as a slitting saw using a 3/8 threaded Clarkson style end like you see on threaded end mills?
I am wanting to set up a small slit cutter and use in my BCA jig borer which I have a collet that accepts the 3/8 threaded end mills and was hoping such a beast exists? If not I guess I am off down the path of making one.....
Ian
13th Apr 2020, 04:20 PM #2Most Valued Member
- 4,890
Don't think you will find a threaded arbor to suit your needs, why not just use a plain shank arbor that suits your collet diameter or make your own?
13th Apr 2020, 04:28 PM #3
Hi Ian, Guys,
I've never seen a threaded mandrel like you describe ! It is very likely that you will have to make one. However 3/8" is a bit thin for a slitting blade, even for a 32 mm diameter one. My 32 mm X 0.8 mm blades have 3/8" bores (9.525 mm ) diameter.
Its not too long ago I had to make a mandrel to use one, and 1/2" diameter was only just enough.
I'm running this between centres on the lathe.Best Regards:
13th Apr 2020, 08:13 PM #4Senior Member
- Feb 2012
- Tamworth, NSW
- 205
Thanks guys - looks like I better add this to my list of projects. My mill is small and largest collet is 3/8 so that will have to be the shank size.
Clarkson autolock - I like it
By StrayAlien in forum METALWORK GENERALReplies: 25Last Post: 25th Jul 2019, 11:14 PM -
NT 30 Clarkson Autolock chuck
By TomW in forum WANTED TO BUYReplies: 0Last Post: 19th Jul 2019, 06:13 PM -
Where can I buy Affordable Acme Threaded Lead Screw & Flanged Acme Threaded Nuts
By RoyG in forum METALWORK GENERALReplies: 8Last Post: 1st Sep 2014, 12:26 PM -
Clarkson threaded tooling into ER Collets?
By Com_VC in forum METALWORK GENERALReplies: 10Last Post: 8th Mar 2012, 01:33 AM -
Clarkson chucks
By Stustoys in forum METALWORK GENERALReplies: 15Last Post: 26th Dec 2010, 09:41 PM
