Results 1 to 15 of 16
11th Apr 2020, 08:44 PM #1Senior Member
- Sep 2009
- Newcastle
- 341
LED Shed lighting, plug in options?
My shed is a two car garage. Lighting is poor - a central double fluoro in each bay.
I'm looking for the best plug in LED option. I want to be able to move the lights around in future as needs change.
Ideally I'd like lights that can be linkable / daisy chained (cord from one light to the next) instead of all requiring a separate power point.
Some options I've found:
Osram / Ledvance LED Panel - 32w, 3200lumens. https://reductionrevolution.com.au/p...light-1200-300
Or cheaper in daylight 6500k only: https://reductionrevolution.com.au/p...nel-1200-x-300
2050lumens per 18w tube: https://thelightingoutlet.com.au/pro...n-saa-approved
40W, 4400lumen, no brand specified: https://www.lighting-wholesale.com.a...v=6cc98ba2045f
Linkable but not great price: https://thelightingoutlet.com.au/pro...ighting-sl9706
I prefer known brands. Sick of replacing the cheap LED bulbs that the previous owner put in here.
What colour temperature is best? I strongly prefer warm whites in house lighting but different situation of course.
Keen to hear peoples experience of specific products.
11th Apr 2020, 08:56 PM #2Senior Member
- Sep 2009
- Newcastle
- 341
A couple more options:
Osram linkable, 12W 1350lumens for $21.06: https://thelightguys.com.au/products...n-12w-220-240v
Verbatim linkable, 14W 1250lumens, $16.75: https://thelightguys.com.au/products...16089350438955
11th Apr 2020, 09:12 PM #3Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 312
I use these but in cool white. https://www.ebay.com.au/itm/35265786...84.m1436.l2649
11th Apr 2020, 09:28 PM #4
I like the 6500 cool white. Great for my eyes.
I bought 10 tubes from someone selling aeg gear.
Wish I had bought a few more for my veranda carport etc.
Depending where you are it’s free freight.
11th Apr 2020, 09:32 PM #5
aeg-electrical
On epay
11th Apr 2020, 10:13 PM #6Golden Member
- Jun 2005
- Helensburgh
- 618
Any light can be plug in, all it need is a 3 pin plug on it. I put unswitched 3 pin roses in the ceiling and then plugged all the lights in to those. I can put double adaptors on the rose and add an additional light, use an extension cord to move a light etc.
CHRIS
11th Apr 2020, 11:43 PM #7
If you want to go to the woodwork part of this forum I posted on the 31st March in General under Shed about getting my shed retrofitted for $33 with LED lights.
They replaced 30 lights.
H.Jimcracks for the rich and/or wealthy. (aka GKB '88)
12th Apr 2020, 09:38 AM #8
I went for 1100x300 LED X 4 formed in a broken square, hard wired 2x separate switches so I can have 2 or 4 on. I like you had 2x single fluro in a double garage. It cut bills by 25%.
12th Apr 2020, 11:29 AM #9Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
FWIW I've used multiples of these 12V LEDs attached to the walls and ceiling when I needed even lighting inside a temporary enclosure (DIY spray booth), ran them off a 12V jump starter battery pack.
https://www.ebay.com.au/itm/264445195432
12th Apr 2020, 12:37 PM #10Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
I prefer Cool white and that's what I use both in the house and the shed at home. I have Led Fluoro's at my business when I'm back there on tuseday I will see what they are and let you know.
All The Best steran50 Stewart
12th Apr 2020, 02:37 PM #11Senior Member
- Sep 2009
- Newcastle
- 341
Thanks for the replies.
I'll go with cool white.
Going to try the Osram linkable ones.
14th Apr 2020, 10:10 AM #12
14th Apr 2020, 10:35 AM #13Diamond Member
- Sep 2006
- 53
- 1,010
I just looked at the spare tubes for my Led Fluoro's at work and the box doesn't really give much info apart from that they are a 18Watt T8 Led Tube and marked as 'Bright'. I actually would've prefered them to be brighter than what they are.
15th Apr 2020, 10:38 AM #14
This is my set up 1100x300 slimline LED panels 6000k lumin daylight fixed setting. 1st photo lights on with garage door open, door closed 2 light's on, then door closed 4 panels on. You can see on the ceiling towards the other garage doors the panel light turned off and on, the other was almost above my head.
With all 4 on I get little to no shadow at all.
In our kitchen we have a 600mm sq panel Sue can work at any surface without shadow. These all installed by electrician to hard getting into roof in a wheelchair to hard wire.20200415_092232.jpg20200415_092419.jpg20200415_092521.jpg
15th Apr 2020, 07:32 PM #15Banned
- Mar 2020
- Sa
- 24
I hardwired two Fluro lights along with power points in my 5x5 workshop after the shed was constructed, then had an electrician check everything and connect to the meter box. Didn't think I'd need lights as I only work out there during daylight. The fluros proved inadequate on overcast days, so, I installed clear panels in the roof, still not enough, so, I bought two single, 4' LED lights from Bunnings, wired them together and attached a three pin plug to them - brilliant, they proved plenty and I don't use the fluros anymore. Just make sure you get the cool white LEDs.
15 Amp Plug
By bwal74 in forum ELECTRICALSReplies: 11Last Post: 13th Jan 2019, 12:22 PM -
Lighting Unobtanium
By david.elliott in forum METALWORK GENERALReplies: 12Last Post: 24th Jan 2014, 09:36 PM -
Shed heating options
By 19brendan81 in forum METALWORK GENERALReplies: 63Last Post: 22nd Jul 2013, 09:34 PM -
Lathe lighting
By BobL in forum THE HERCUS AREAReplies: 2Last Post: 21st Jun 2011, 10:48 AM -
buying first mig - have 20 amp fuse but 10 amp plug outlets in shed..
By woodmama in forum WELDINGReplies: 86Last Post: 27th Apr 2009, 02:48 PM
