Results 1 to 9 of 9
    Dec 2005
    South Australia
    1,657
    Default Better finish on brass
    Hi all
    I am in the process of turning some Brass, ( see att.)if possible I would like to, gain a better finish, I am using hand fed HSS hand ground tool
    Can I use a knife edge type tool as can be used on steel or am I basically stuck with cleaning it up with emery paper once the machining is complete, also do I use the same parting tool as for steel.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Are you using a negative rake tool?
    Dec 2005
    South Australia
    1,657
    No it is slightly positive
    34
    1,079
    I've found that carbide inserts for aluminium (polished top and ground edges) work really well at high spindle speeds. Power feed is ideal, but if you can keep your hand feed smooth it's still a very good finish.
    It's counter intuitive because they have a high positive rake, but they do the job
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Try a negative top rake.
    Dec 2005
    South Australia
    1,657
    Thanks for the advice I will let you know what happens
    Sep 2009
    Sydney
    666
    When I’m watching Clickspring I always notice he has a very sharp cutting cool with a positive cutting rake. Way sharper than for steel or
    Alu.
    I’ve never turned bronze or brass but maybe try a cutting tool like that:
    https://youtu.be/o8Bd8G21Vv8
    Dec 2005
    South Australia
    1,657
    Update, I ground a new tool and left it with no top rake made a big difference not a perfect but the best I can expect from my lathe, just leave a small touch up by hand.
    Question No. 2 Should I grind the parting tool the same with no top rake or leave it as it is for steel, parting depth will be 5mm
    34
    1,079
    Leave it neutral as well
  1. Clear finish for brass
    By China in forum METALWORK GENERAL
    Last Post: 5th May 2019, 11:42 PM
  2. Brass Casting, Poor Surface Finish
    By NedsHead in forum THE FOUNDRY
    Last Post: 30th Jul 2018, 12:40 PM
  3. Threads on finishing, finish, good finish
    Last Post: 20th Jan 2014, 06:53 PM
  4. How to polish brass to mirror finish?
    By wsal in forum METALWORK GENERAL
    Last Post: 11th Nov 2011, 02:52 PM
  5. Brass/Copper finish
    By cookie48 in forum METALWORK GENERAL
    Last Post: 7th Jul 2011, 09:14 PM
