Results 16 to 22 of 22
Thread: Lining up for vertical Milling
3rd Apr 2020, 09:09 PM #16
4th Apr 2020, 12:44 AM #17
Hi Phill,
Yes that is the shape I use, unless I'm going for a square face or a dovetail.
These are three pictures of my go to general purpose fly cutter. As you can see the toolbit is round ended. It has a 20 mm diameter shaft and I use it on both the mill and lathe. It is particularly good on cast iron, because of its rigidity.Best Regards:
4th Apr 2020, 02:28 AM #18
4th Apr 2020, 07:40 PM #19
Hi Phill,
It might be better to just use a piece of steel and drill a hole in it to hold a bit of HSS like in the pictures. It doesn't have to be round, anything that you can clamp in the four jaw that can be adjusted to give the radius cut that you need.Best Regards:
4th Apr 2020, 09:15 PM #20
The knowledge.
The skill.
The license to ill.
4th Apr 2020, 09:18 PM #21
John, I couldn't get the 4-jaw to work on its own, so inspired by your pics, I made up a little tool to go on the thing I use as a face-plate.
It is working a treat, one more pass to go tomorrow, and I'll dismount the vertical sled & see how it went. I have to say that making square holes in steel is not a lot of fun
5th Apr 2020, 02:07 AM #22
Hi Phill,
Well done
I would have just drilled a round hole and used the square HSS material in the hole. Too much like hard work filing a square hole.Best Regards:
Vertical spotter
By DSEL74 in forum METALWORK GENERALReplies: 19Last Post: 1st May 2017, 04:02 PM -
Vertical slides
By th62 in forum METALWORK GENERALReplies: 42Last Post: 13th Nov 2013, 05:26 PM -
What's in a vertical head?
By neksmerj in forum METALWORK GENERALReplies: 25Last Post: 19th Apr 2011, 05:11 PM -
vertical up arc which electrodes ??
By barney702 in forum WELDINGReplies: 7Last Post: 10th Mar 2010, 07:13 PM -
Vertical Mill
By Filby in forum METALWORK GENERALReplies: 8Last Post: 18th Aug 2009, 03:39 PM
