Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Apr 2009
    Kingswood
    930
    My contribution is a pair of drill table clamps.
    These only work on a table with slots open underneath.
    Made my first pair in 2010, and have made about 8 pairs since, given away to friends.
    The vice is no longer on the table, and is rarely used.
    Intend making another two, one longer beam and one symmetrical beam (perhaps during lockdown !).
    Once made and used, you will find them being used daily.
    A clamp can be inserted from below the table.
    I have become adept at holding the job with the drill quill down using right hand, pick up a clamp with the left hand, insert it, reach for a support, and tighten.
    Clamp works with thin pieces without support, works with tall (<80 mm) piece with supports.
    When hole drilled, instant clearing of the table.
    Tube is common 19 mm tubing.
    Nut is M12 cleaned up in lathe to circular.
    Tube cleaned up for a glued fit of the nut.
    Washer (thick) is MS off lathe.
    Screw is M12 threaded rod cut to length, flat tongue filed into end, tongue drilled for rivet.
    Beam is 10x20 black, filed to give end projections, drilled and filed for tongue recess, drilled for rivet with countersink.
    Rivet is much better if hollow.
    Handle is rod flattened at ends.
    Check depth of arm below the table before selecting tube length, AND, make them different lengths to reduce handle interference.
    John
  2. #17
    Jul 2016
    35
    1,522
    Those clamps are great. Good original idea!
  3. #18
    Jul 2009
    perth
    67
    Thanks John
    Them drill press clamps look extremely fit for purpose. I will be making a couple of sets
    Tom
    Sent from my SM-G965F using Tapatalk
  4. #19
    Mar 2009
    54
    825
    Not really a project as such but still a lockdown related activity.
    My 12 year old son has lined up a few projects that will require some welding so I figured it’s a good time for him to learn how rather than me doing it for him.
    He started off doing straight runs with no filler to get a feel for the torch then progressed to adding filler before doing some butt joints in 5mm rod.
    I’m certainly no expert but his progress seems to be pretty good after only a few hours and he’s moved on to welding parts for his first project.
    Greg.
  5. #20
    Mar 2011
    Southern Flinders Ranges
    1,536
    Along similar lines I started building a hammer with the 9yo while we were waiting for school to get an online presence sorted out..
  6. #21
    Jan 2004
    Mackay North Qld
    6,446
    I like this one .Your boy will have a real advantage when he gets to high school in the what was Man Arts now Technology
  7. #22
    Jan 2004
    Mackay North Qld
    6,446
    Quote Originally Posted by kwijibo99 View Post
    Greg.
    Again I think it is great to get the kids into the shop on this sort of stuff
    Good on you.
  1. Some of my projects
    By bts in forum METALWORK PROJECTS
    Last Post: 20th Sep 2018, 08:46 PM
  2. Tafe Projects
    By fittermachinist in forum METALWORK GENERAL
    Last Post: 5th Aug 2012, 06:44 PM
  3. Projects page
    Last Post: 7th Oct 2011, 02:51 PM
  4. Projects Blogs FAQ .. Projects Blogs FAQ .. It's deja-vu all over again
    By Ron Dunn in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 24th May 2008, 10:18 AM
  5. First projects
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 15th Jul 2007, 09:59 PM
