Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    May 2019
    Picnic Point, Sydney
    77
    314
    The first thing you need to do is determine if the lathe is turning parallel.
  2. #17
    Jul 2010
    9,088
    Quote Originally Posted by steran50 View Post
    I am aware Stustoys that the headstock had been removed and then it was refitted.
    Then given what the OP wants to achieve, why are you worried about twist?
    Quote Originally Posted by Snapey View Post
    Why?
  3. #18
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    No further comment.
    All The Best steran50 Stewart
  4. #19
    May 2019
    77
    314
    Originally Posted by Snapey The first thing you need to do is determine if the lathe is turning parallel.
    Why?
    Your bed and saddle should be at 90 degrees to each other so if your test piece is parallel then the face should be flat.
  5. #20
    Sep 2004
    Dardanup W.A.
    72
    331
    So a slight adjustment to the headstock ended in a 0.045mm centre cup, way better than I had hoped for, and allows me to finish the project I was working on.
    It is really nice to drill through a 75mm piece of steel and have the hole appear in the correct position on the far side
    When this project is done, it will be time to start from scratch & set the lathe up properly.
    Thanks for all the info provided, much appreciated.
  1. Herless Lathe Headstock Bearings
    By FTO_dude in forum METALWORK GENERAL
    Last Post: 8th Apr 2014, 08:12 PM
  2. Tapered Gib Adjustment
    Last Post: 14th Nov 2011, 08:21 PM
  3. Lathe headstock and tailstock are out of alignment
    Last Post: 22nd Nov 2010, 03:00 PM
  4. [repost] Home Made Lathe - Can anyone turn a headstock spindle for me?
    By Skew ChiDAMN!! in forum METALWORK GENERAL
    Last Post: 26th Aug 2007, 04:04 PM
  5. Welder adjustment
    By mike j in forum WELDING
    Last Post: 16th Aug 2007, 09:09 PM
