Results 1 to 9 of 9
16th Mar 2020, 03:40 PM #1New Member
- Mar 2020
- mid north S.AUS.
- 87
- 2
shaoxing machine tools cq6230 lathe spindle switch
Can someone supply me the wiring color code / number code for the spindle switch connection to the terminal block in the Electrical Cabinet of my CQ6230 lathe please?
my wire colors are blue, brown white and black.
thankyou
Govy
16th Mar 2020, 07:26 PM #2Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
This may or not help. The Grizzly G4003G is apparently the equivalent lathe. If you go to this weblink https://www.grizzly.com/products/Gri...h-Stand/G4003G and then go to Documents and download the Manual and go to page 81 of the manual the wiring starts there.
All The Best steran50 Stewart
19th Mar 2020, 04:40 PM #3New Member
- Mar 2020
- mid north S.AUS.
- 87
- 2
cq6230
Thank you steran50 for your reply. My lathe is a 1998 year make and is totally different to the Grizzly G4003g. Any other suggestions would be helpful.
Thanks Govy
19th Mar 2020, 08:06 PM #4Diamond Member
- Sep 2006
- 53
- 1,010
Sorry Govy that I wasn't much help. I have a Hafco AL960B but mine only has the power coming into the motor fwd/rev switch and then straight to the motor so the wiring on that probably wouldn't help either. I'm suprised someone else hasn't responded as their must be plenty of CQ6230 owners on here. Perhaps try asking in the 'Electricals' section and maybe post some pictures.
20th Mar 2020, 03:02 AM #5
Axminster in the UK do a manual for a CQ6230 Lathe.Best Regards:
20th Mar 2020, 08:04 AM #6Senior Member
- Jun 2012
- melbourne
- 341
Whats a spindle switch? Is that the interlock on the chuck safety cover? Or the forward/reverse lever on the aprin? Or is there some switch on the spindle itself?
I put some photos of the contactors driving the motor back here. https://metalworkforums.com/f65/t202...p-al336/page-2 just in case its anything to do with that.
I'm not certain your lathe is the same as an al336 but they look similar when I checked on google.
20th Mar 2020, 05:39 PM #7
Post up a picture of your lathe and the switch.
The cq6230 is a very generic model produced and reproduced by many. If someone on here has the same model they might dig further for you.
Mines a Jan 1994 model
20th Mar 2020, 07:40 PM #8Golden Member
- Dec 2011
- 505
... you can download it from here: https://www.manualslib.com/manual/53...30a-2-910.html
Has 69 pages seemingly with some exploded diagrams.
Bill
21st Mar 2020, 10:18 PM #9
This pdf colour-coded wiring diagram I made back in 2006 from my 2001 model of the CQ6230A (made by Shaoxing Tongli Tool Co. and imported by Hafco), might help you. Attached below.
Actually the size of the diagram is made just right to print out and stick inside the cover of the control box.
Also refer to the instruction book (with manufacturer's wiring diagrams) for the Hafco CQ6230A uploaded here: https://archive.org/details/CQ6230AManualLast edited by Gunnaduit; 22nd Mar 2020 at 08:43 AM. Reason: Updated wiring diagram
Spare parts for 1994 CQ6230 12x36 lathe
By keithg in forum METALWORK GENERALReplies: 16Last Post: 29th Dec 2020, 08:38 PM -
Milling Machine broken switch replacement where to buy ?
By topari in forum METALWORK GENERALReplies: 19Last Post: 20th Dec 2016, 09:15 PM -
CQ6230 12x36 lathe, good for a tax refund spend?
By benja in forum METALWORK GENERALReplies: 6Last Post: 7th Jul 2012, 12:19 AM -
CQ6230 Lathe - Gearbox Drain Plug Location
By Blu_Rock in forum METALWORK GENERALReplies: 6Last Post: 11th Jan 2012, 09:49 AM
