Page 5 of 5 FirstFirst 12345
Results 61 to 64 of 64
  1. #61
    Apr 2012
    Healesville
    2,129
    I'm not sure how you would go about truing that crank but I think the el cheepo indicator that you have should get it close enough.
    Are you planning on pressing the crank pin into one flywheel then partially press the other side on, check and true, press a bit more and check and true and so on?
    In the distant past I did many m/cycle cranks but back then they had tapered crank pins and I think might have been a bit simpler to true than that yammy crank.
    Here is some useless info....the method in the factory Harley Davidson WLA manual to true the flywheels is to sit a ruler across the 2 flywheels and when the ruler is sitting flat across the 2 flywheels then tighten the crank pin nuts....things were so much simpler then
    shed
  2. #62
    Aug 2009
    Sydney, NSW, Australia
    1,844
    Thanks guys i need a decent DI so i will get that one from H&F
    I plan on pressing the pin into one side than the other yeah but once shes together im going to have to tap her around to get it running true
  3. #63
    Nov 2007
    Near Rockhampton
    270
    This bloke might give you some hints on doing a cheap job on your crankshaft.
    https://www.youtube.com/watch?v=vVgOYyLwy_Y
    No fancy dial indicator required.
  4. #64
    Aug 2009
    1,844
    John lol they are crazy over there i guess clearance and roundness doesnt matter on a scooter they all vibrate i dont think scooters have balance shafts either my YZ250F does so the alignment of the crank webs is very critical
  1. Opening a used LPG Cylinder
    Last Post: 21st Nov 2019, 11:24 PM
  2. Hydraulic Cylinder Fix
    By RustyArc in forum METALWORK GENERAL
    Last Post: 2nd Dec 2018, 09:22 AM
  3. Hot Cylinder on Two Stroke
    By Goggomobile in forum AUTO RESTORATION
    Last Post: 17th Sep 2016, 01:46 PM
  4. cylinder hone
    By leroy in forum METALWORK GENERAL
    Last Post: 16th Mar 2014, 02:33 PM
  5. mig gas cylinder volume ?
    By barn in forum METALWORK GENERAL
    Last Post: 18th Aug 2007, 06:07 PM
