Results 1 to 3 of 3
5th Mar 2020, 07:43 PM #1New Member
- Jun 2017
- 2
Help Identify Metal Lathe face plate mount.
Hi,
I am trying to identify what sort of mount this face plate uses.
It has a mount for a short nose taper which is 82mm in diameter at the start of the taper (I can't measure the inner diameter at this moment).
The face plate is around 280-285mm in diameter (so I assume it is 11") with four holes for mounting bolts and an additional hole for a locating pin perhaps?
The only other spindle nose mount other than the d1- types that I found is a A2 Short nose taper.
Does anyone know what this mount is?
I will attach some pictures with approximate dimensions.
Cheers.
5th Mar 2020, 07:53 PM #2Most Valued Member
- 4,887
Some of the sizes look close to an A1 short taper, you may need to provide or at least work out the PCD, inner taper diameter and check with a protractor the taper.
5th Mar 2020, 08:45 PM #3Philomath in training
- 6,542
May help
Lathe Spindle Nose and Backplate Fittings
Lathe chuck swapping issues (face plate on threaded spindle)
By nigelpearson in forum METALWORK GENERALReplies: 22Last Post: 7th Nov 2019, 06:48 AM -
Lathe face plate 14.5"
By Petip in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 20th Jun 2018, 04:09 PM -
hercus ,qualos lathe face plate and chuck back plates
By KBs PensNmore in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 7th May 2017, 02:13 PM -
Compact Workpiece Clamps for the face plate and angle plate.
By metaler in forum METALWORK PROJECTSReplies: 0Last Post: 10th Oct 2016, 07:16 AM -
Fitting a 250mm chuck on a face plate, 12x36 lathe
By Dave J in forum METALWORK GENERALReplies: 8Last Post: 7th Aug 2010, 12:57 PM
